how to build 302 chevy
I was tossing the Idea around of building a 302 chevy to put into a third gen and make my own 5.0 high output f-bod. I want to kind of mix first gen and third gen.Any way I was wondering what exactly I need to build one. I'm thinking a 350 block and a 283 crank? I was wondering b/c I thought I read that all 283's were small journal? I was just looking for advice on how to build the shortblock.
I don't want aLn exact replica 302, just want to get that displacement. Any help would be great, thanks!
P.S I would rather use a gen I small block than a LT1. But I have both gen I, and gen II in my garage so whatever works.
Josh
Josh
Re: how to build 302 chevy
You need the 283 crank and a set of small journal rods for a 283 or early 327. Aftermarket rods are also availible with 2.00" rod journals. You also need a 4" bore piston with the same compression height as the 283. Don't know about that number off hand. Everything else is the same including the main jounals.
I believe you can also go late model (Gen I or LT1) with a Caprice/Roadmaster 265 crank with a 1 piece rear seal. You will need 302 pistons, but standard 350 rods - check the crank you end up with.
The early model set-up will require small journal rods.
so i can use a 350 block and a 283 crank.Thats what I thought. Does anyone know who sells repo new/recondition 283 cranks? I downloaded Eagles catalog on pdf and they don't offer one. Any helps great right now.
Josh
Josh
the l99 is from the caprice its the baby lt1,this engine actually displaces 4.3L BUT its a v8.GENERAL MOTORS' Mark Mcphail created this special 302 a few years back in an lt1 form and it rocked!
Thats sweet! Thanks for the help, another ? though will that 4.3 L99 crank work in any 1 piece rear 350 block? Does anyone have a web site or more info on the build up of a chevy 302?
Yes it will work in the earlier 1 piece seal blocks just fine, you will want to use the stock 5.94" rods from it and off the shelf pistons for a 350, or you could go chasing down other parts if you want something stronger.
NewsBot
Mar 16, 2015 12:51 PM
CARiD
Jan 14, 2015 04:00 AM
formula79
18
Jul 1, 2002 02:39 PM
