SLP question
Old Dec 25, 2004 | 01:17 PM
Sceanzo's Avatar
SLP question
Hey dudes, I just order my SLP LM for my 95 Z yesterday
My question is how hard is it to install, i have no money right now since i spent it all on my exhaust, but i do have a good amount of tools,
I bought the Single Cat Install kit for it to
I have some minor experience working on cars but not a GURU at it
How long did it take you guys, what did you need, should i just save some cash and let a muffler place do it for me
Old Dec 25, 2004 | 05:59 PM
Fuels94TA's Avatar
Re: SLP question
The only thing that will slow you down is taking the old system out cause of old bolts, also you will need to cut the pipe around the axle area so the old exhaust system will come out. The new system will be easy, you will use the same hanger areas and slip fit the pipe together and just use the clamps that come with the kit. It should take no more the 2 hours, also jack the car up on all four area nice and high so you can do the work comfortable on your back. For me I wasnt to crazy with the clamps so I took it to a shop and just had then weld the fittings.
Old Dec 25, 2004 | 09:06 PM
PipesTA's Avatar
Re: SLP question
It's a breeze to put in. Shouldn't take you more than a couple of hours if you're farmilar with your car.
Old Dec 26, 2004 | 12:00 AM
kingman109's Avatar
Re: SLP question
takes about 20 min* -
*if ur lucky and bolts arent bad -- else as long as it takes to remove abotu 6 bolts
1) cut stock exhuast at axle bend with saws all -
2) unbolt near cats- (use PB Blaster or somethign like)
3) unbolt the 2 supports near rear
4) remove pipes
5)bolt new bracket on driver side
6)put new pipes in reverse order
done
drive around obnoxiously pissing off neighbors
Old Dec 27, 2004 | 07:02 PM
Beyonce Knowles's Avatar
Re: SLP question
I recomend a dremel w/ cutoff wheels and a sawzall. That'll make quick work of the old system.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
novaiiman
May 15, 2016 11:36 AM
Kyle@SLP
Jan 7, 2015 02:09 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
