Squeaking in the rear hatch ???
Old Dec 23, 2004 | 11:41 PM
crAzy95z28's Avatar
what is squeeking? makes alot of noise over ever little bump... sounds like a rat!!
let me know if it is possible to fix!!!
Randy
Old Dec 24, 2004 | 12:02 AM
Lt1t56's Avatar
Re: Squeaking in the rear hatch ???
I have had the same problem with both my cars, most noticed on colder days. My problem was the rear sway bar bushings. Remove the bushings, coat the inside of them with wheel bearing grease and reinstall, fixed my problem. 15 minute fix.
Old Dec 24, 2004 | 12:03 AM
anasazi's Avatar
first thing to check is the little bump stop things, turn them out a twist or two and see if the squeek goes away.
if not, it might be the struts themselves. have a friend sit in the back seat while driving and start pushing on the struts to see if the squeek goes away.
in my old 95 z28 the top of the strut was loose and squeeked like crazy.
Old Dec 24, 2004 | 09:20 AM
slayer6x6's Avatar
My car has the same noise, it drives me friggin nuts!!!
Old Dec 24, 2004 | 10:04 AM
Hawk#1412's Avatar
Mine did the same thing.... Chris (aka IrocSS85 here) took care of mine for me one day at the dealership. Found out that it was the right exhaust hanger that was rubbing. Good luck tracking you'rs down.
Jeff
Old Dec 24, 2004 | 11:24 PM
91 Camaro RS's Avatar
Mine did the same thing when I got it, but I put Armor All on ALL the seals (doors, hatch, t-tops, etc) and no more squeak.
Old Dec 25, 2004 | 10:41 AM
1995greenTA's Avatar
Mine was doing the same, and i rapped electrical tape around the metal hoop that holds the hatch closed and it took care of mine. Your going to get alot of different answers because there are alot of different noises that come from our cars. Good luck.
Old Dec 25, 2004 | 11:47 AM
Bow94z's Avatar
HAve a friend push on the struts while youre driving...Thats what mine does, i need new ones or try and grease them up...yup sounds just like a Rat back there
shroyvin56
Apr 3, 2015 08:15 AM
Jan 13, 2015 09:52 PM
siguy
Nov 27, 2014 10:07 AM
Bando
Oct 7, 2002 07:36 PM
regular Joe
Aug 8, 2002 03:47 PM
