Fixing cracked center consol
Old Jan 4, 2005 | 11:49 PM
atljar's Avatar
Well the other day when it was like -15 i pulled up my ebrake and it actually cracked off a piece of the plastic b/c it was so cold.
Thoughts on fixing it, fiberglass, some kind of epoxy? What works well? Color is black so should be easy to match, but i have to get the fake grain in there somehow too.
Old Jan 5, 2005 | 12:27 AM
Z95m6's Avatar
Re: Fixing cracked center consol
The best fix would be getting a plastic welder and actually welding it. Besides that I've also had good luck with an epoxy that Walmart carries called Plastic Welder. Its rated at up to 3500 psi and is extremely strong and bonds well. I suggest that. It sets up in about 5 mins and is completely hardened after 24hrs.
Old Jan 5, 2005 | 12:33 AM
atljar's Avatar
Thanks for the reply. I havent found the chip it broke off yet (likely under the console somewhere). But if i dont find it, is the epoxy tacky/thick enough to reform the missing piece to start with? Its only 1 inch by .5 inch or so
Old Jan 5, 2005 | 04:36 PM
IROC-T's Avatar
Yes it is somewhat workable but you'll probably need to practice on something first just to get an idea how fast it sets. I found that a little over build ,and then sand to size works better,and it does dry to a cream color so painting will be required. If yo find the missing piece just put a little on the edgethen build it up underneath for an almost invisible fix.
Old Jan 5, 2005 | 05:19 PM
atljar's Avatar
Thanks to the both of you again
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
F'n1996Z28SS
Aug 23, 2023 11:19 PM
mattstrike
Mar 11, 2015 07:33 PM
CaRParts102
Dec 6, 2014 08:45 AM
My94M6
Dec 6, 2001 07:21 PM
