alternator brace
Old Jan 14, 2005 | 11:10 PM
fredmr39's Avatar
alternator brace
didn't put the alternator brace back on the bottom back of alternator - wasnt it bolted to engine? no room now with headers- am i fine without that one? been running 2 days, holds fine
Old Jan 15, 2005 | 04:25 AM
Kris93/95Z28's Avatar
Re: alternator brace
I left mine off on my old 93 Z28 after my header install.
I didn't have any issues and it was like that for around 2 1/2 years.
Old Jan 15, 2005 | 09:36 AM
bozobuttz's Avatar
I installed my passenger side header just the other day and I didnt put the brace back in either.
Old Jan 15, 2005 | 04:33 PM
NOMAD's Avatar
I don't have any of the bracing on mine
-Shannon
Old Jan 15, 2005 | 11:13 PM
rpm4lalo's Avatar
-Shannon
Same here.
Old Jan 16, 2005 | 08:35 PM
fredmr39's Avatar
good to know im not the only one - thanks guys/gals, just haven't heard this brough up before
Old Jan 17, 2005 | 10:29 AM
Z28barnett's Avatar
I put the brace back on mine with SLP 1 3/4.
I ground down one side of one of the factory bolt spacers to a "D" shape to miss the header flange. The spacers are about the same thickness as the factory exhaust flange.
I then stacked another stock spacer on top of the "D" shaped spacer. This puts everything at the the right height. The factory bolt goes back into the very front hole on the passenger side head. This bolt hole is not used by the headers.
Then you tighten everything up with the factory bolt/stud, place the bottom of the brace over the stud and tighten the nut.
Oh, by the way it might be a little tight to get a wrench in there, but it will work. Depending on the header you might have to grind the flange.
Z28
Old Jan 17, 2005 | 10:47 AM
1stz28's Avatar
Z28
I did the exact same thing with my SLP 1 3/4 except I think I remember using a nut as one spacer...can't remember exactly why unless I was trying to match the thickness of the factory manifold. I originally left the bracket off but it just bugged me since I thought I could get it on there. It is indeed a tight fit...both the bracket nuts and the header bolt but I now have a custom ground socket and two custom ground and bent box wrenches used just for my header bolts. I can now reach and tighten all my header bolts from the top.
Old Jan 17, 2005 | 11:57 AM
hotrod18_69's Avatar
Ditto, don't sweat it. Its fine with it not on there.
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
Slayer
Aug 17, 2015 03:55 PM
