Firebird headlight problem
Hey I was just wondering if anyone knew how to fix this. Theres a setting for the firebird where you can make your headlamps come up but not turn on when you're lamp switch is in parking lights mode. I just turned this feature on and really need to turn it off, so the haedlamps only come up when its in headlamp mode. Any suggestions?? It tells how to put it in this mode in the owners manual, but not how to disable it. Thanks for any help!
Re: Firebird headlight problem
On my 1995 T/A if you turn the switch to the first positon the park lamps come on, if you turn it to the second positon the headlights come on, then if you turn it back to the first position the park lights are on and the headlights stay up but not illuminated. I beleive this feature is for cleaning the headlights. If you just want park lights on turn it to the first position.
Six Speed you are a genius, I owe you. My gears do grind and it was really annoying to have them grind everytime i used the keyless entry, but unpluggng the connectors solved it.
Brent, sorry about the multiple postings and old sig file, wont happen again. i tried the free solution to the headlamp motor but now the gears grindgoingdown instead of up. Looks like I 'll be investing in the brass ones soon. Thanks for the info on that fix.
ChrisFrez
02-15-2015 08:12 AM
