what is the likely cause of my car not starting on the first try...
Old Jan 8, 2005 | 03:03 AM
Donohue96M6Z28's Avatar
its been doing this for about a month now, when i try to start my car it takes 2-3 times until it fires up, once its been on for a while, and i shut it off and try to turn it on, it seems like most of the time it will start on the first try, also, today, it wanted to start, but stumbled, then it died , then i tried again, and then it started right up, a couple days ago, my service engine light came on, i went by autozone and they said the light came on bc of spark plugs and/or wires, now the light is off, but do u think maybe the spark plugs might be the prob w not firing right up? or do u guys have any other ideas? any help is appreicated, thanks
Old Jan 8, 2005 | 09:12 AM
Fuels94TA's Avatar
Re: what is the likely cause of my car not starting on the first try...
Properly the reason for the light is engine misfire since the car doesn't start up correct. When was the last time you changed the fuel filter? Also a weak fuel pump can be the problem on your start up.
Old Jan 8, 2005 | 10:44 AM
unvc92camarors's Avatar
yea, that was my guess too
fuel related
but yea, i'd replace the fuel filter and spark plugs, since you should do it every so often anyways
if it still persists, might be a weak fuel pump or the wires
you could try priming the fuel pump and see if it works
just turn it to run, then turn it to off
do that 3-4 times then start the engine
if it starts fine doing that method, it'll most likely be a weak fuel pump
Old Jan 8, 2005 | 11:29 AM
ya engine misfire is what they said but that plugs/wires should fix it,i guess ill try that fuel pump test to see if its bad etc, thanks for the help guys
Old Jan 8, 2005 | 12:06 PM
9C1/B4C's Avatar
One temporary way around a weak fuel pump, or a bad diaphragm in the fuel pump (lets the fuel pressure bleed off overnight, or when parked for a while), is to turn the key to on for 5 seconds, then back to off, then on for another 5 seconds, then off, then try to start the engine. If it starts right up after that, a fuel pump might be in your future. I believe the check valve is in the fuel pump, but a bad fuel pressure regulator can also allow fuel pressure to bleed off the lines.
Essentially what this does is prime the fuel line and builds pressure before the start. If everything is working well, the pressure in the fuel line should hold overnight. And with a strong pump should build immediately when the key is turned on.
All that said, a clogged fuel filter can slow all this up also.
Terry
Old Jan 8, 2005 | 12:44 PM
Terry
i stated that up there
thanks though for clarifying it, maybe i didn't explain it well enough
Old Jan 8, 2005 | 08:19 PM
9C1/B4C's Avatar
My bad, I just didn't read all of your post. You actually explained it better than I did -- less words. Sorry
Terry
Old Jan 8, 2005 | 09:49 PM
Terry
well, atleast he got the point either way
Old Jan 9, 2005 | 11:06 AM
i changed the fuel filter yesterday but im still havin the prob, so im thinking its prob the fuel pump now , thanks guys for ur help, i appreicte it
Old Jan 9, 2005 | 01:04 PM
tanker's Avatar
yep, its most likely the fuel fump; my brother had same symptoms. Too bad fp is such PITA to change. At least the part is not expensive
Noenav
Mar 1, 2019 07:38 AM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
teedoff59
Aug 8, 2002 01:36 AM
