- will a 3.4 liter ac compressor work in a 96 lt1?
- '95 Camaro as first car?
- insight/experience PLEASE!
- Once and for all, please the bigger then you need throttle body question..
- z28 keyless entry fob
- Overheating Situation
- brake light issues-ideas? and others
- Purple wire, dead car
- BCM Swap
- Troubleshooting a cruise control problem.
- Seafoam DeepCreep --- Now NO ELECTRIC POWER... HELP!
- Putting on new a/c compressor this week!Please help
- Window fix availble
- SLP rear bumper
- radiator fan question, push fans?
- Rotten Egg smell from exhaust??
- steering shaft
- Reverse Lights Issue: Not the tranny switch
- how many bolts are on the rear of the ac compreesor
- Anyone know anything about 4th gen door locks?
- Will an 02 dash pad plastic fit in my 96?
- Loosey-Goosey Turn Signal
- 1le pulley bolt question
- urgent help please
- Help me out with my little h/c debate please
- 2000 Z28 intermittent start/12 volt supply to coil
- Turn signals won't blink. HU lights dim with brake. Help!
- What do you think?
- replacement seat foam
- What happened?
- 94 z airbag light? & transmission question.
- Steering wheel wear on manual cars
- Camaro Air Conditioning Help
- Auto Gauge VS Autometer
- B4C alternator
- 91 Camaro 28
- Water in Turn Signals
- Parting Out $?
- checking out an early bird
- Temp cooling fan(s) should come on?
- maybe a retarted question
- Crank, No Spark
- High Beams on 1997 Z28 Don't Work
- Wiring Help
- Cooling fans restricting air flow 45 MPH and up !!!!
- Anyone in the Phoenix area want to help me do a t-top conversion?
- Bought a fixxer uppper
- slp package on 95?
- Hit from behind while parked...affects steering?
- Who has fixed their leather seat?
- Something is sizzling on headers?
- No more 02 simms, EPA gets Casper's Electronics!
- 4th gen Firebird dash top, same as 97+ Camaro?
- is my engine misfiring?
- Is there a guage pod that goes to the back of the window?
- Installing gauges
- Compressed Air + OptiSpark, Any Thoughts?
- not using gaskets to seal water pump
- PLEASE HELP security light blinking
- need help fining parts
- Walmart Sale on Mobil 1
- A/C system question
- Is this a real 1994 "intimidator" camaro?
- Hypertech 97-98 LS1 RFG?
- 1le ac pulley
- Window Slides Back and Forth
- will a Vortec Max fit?
- Best way to clean up fire extinguisher residue
- a/c r134a capacty? How much to add to the system?
- WS6 information.
- what to do next?
- Plastic Inner wheel well part number??
- Help with emissions!
- 02 sensor sim . . .
- A Pillar Clips
- bang for your buck
- PSCA in California Aug 3-5th Anyone else??
- creative cold air duct?
- Question for Shoebox or Injuneer
- 4th gen door pins replaceable?
- NEED Help installing AUTOMETER POD GAUGES
- No air from vents. Its 100+ today so NO ac
- AC question
- car is really hot inside
- 450rwhp on tha street???
- LT1 getting 19.5 mpg
- Mixing and matching 93-94 drivetrain parts
- Signal Flasher
- When headlights come on, dashlights go off!! 01 Camaro HELP!
- 1995 Camaro door handle problem (a rod fell out)
- Trans AM Tail light bulb connectors
- Camaro/Firebird Side Mirror Glass Interchangeable?
- Clips
- Help! Where To Install Battery Disconnect Switch?
- How quick does she gooooooo
- Aftermarket Air Filter for 97SS????
- Steering Wheel
- 1997 emissions
- NGK Platinum spark plugs
- Cruise Control stops working - accellerator stuck
- Wiring Issues
- Can't figure out stock security system on 97 Camaro
- Battery dying, radio stays on after key is out?
- Heater Core replacement 1995 Z28 ?
- Need help IDing an '80 Z28
- Help! Wierd Electrical issue...
- Car hitting rev limiter, but there isnt one!
- Winter Help!
- UNGO car security system
- inch of water on floor
- alternator wires
- PSCA. Anyone going in Fontana CA Aug 3-5
- Compression test with headers off?
- 1974 Camaro w/ LT5 swap value?
- Anyone know where to get a dash Plaque for 97 Anniversary SS
- rear bump stops (jounces)
- Buying LT1(salvage)?
- Fiberglass lined socket?
- cooling and electrical issue
- 1997 Camaro dash color
- need to replace entire exhuast and pass in MA
- Ls3 Vs 302
- BBC/T56 Setup with pics
- 96-97 Camaro SS Hood question
- wiper springs
- Lighting assistance
- Should I install new plugs & o2s with header leaks?
- B&M Blackout Gauges
- Nneed Urgent Help W/ Trunk Motor!!
- Trunk Release Issues on 95 Z28
- headlights not working right
- Electrical Issues
- Probably a stupid question, but here it goes....
- Power drain on 95 T/A...
- How much does the starter cost on my LT1
- newbie needs help!
- Help me decipher my RPO codes....
- need help heard a weird noise today
- where is ac condensor
- New Z28 Owner!
- Leaking T-Tops Help
- Formy body question
- Im stumped
- Oscillating A/C
- Water in the rear floorboard and under the seats
- Medium blue quasar Met. what years on ta's?
- dumb question from a newbie
- 67 convert 1/4-panel problems
- Turn signal and brake light issues
- Good Compression tester?
- Tuner Cat question
- How did you wire your manual fan switch?
- braided heater hoses
- Gear Drive
- Parts Stores Not Stocking Alternators
- turbo kit
- good price on 99 z28??
- Radiator leak
- found 69 Z is it real?
- New car with pics!
- 91 camaro tach
- A/C compressor differences?????
- LT1 Sitting for 4 Months
- The hatch.
- New Guy
- How much money should I charge for my AC system?
- starting with CAI
- Fair price? Yes or No?
- ac problems?any help apreciated greatly
- how to get to the 12 second barrier????
- AC problem poor air flow SOLVED
- Relocating the ABS Module....
- What Clips are These??
- Question on this 93 formula
- Good price on this 98 LS1?
- Test drove a 1996 z28 today......
- Turn signal fuse?
- Just Picked up an LT1 Car - Have Pictures & Questions
- New member Seats
- Headlight cover
- throttle body question
- Cold Rattle, hard to find
- AC help,
- How can I tell if it's a real z-28
- Looking for a part Number
- lost keys, with no copies, what do i do?
- what do i need to do to keep up with ls1
- Removing panel under the glovebox and firewall?
- Replaced the Condensor, Questions about recharging A/C...
- Where to get new keys?
- Would a faulty head light switch cause ALL lights not to work?
- 4th --> 1st gen seats
- What kind of oil Pag or Ester?
- Horn Smoke
- AC Charging Question
- How do I know it's really a Z28?
- HELP hitting junk yard this weekend, looking for aftermarket lca's
- 95 Codes
- Turn ignition to "On" position, takes car a few seconds to actually come on
- take foot off gas pedal, what happens on the highway?
- Convertible top replacement instructions? Mods this is a tough one.
- code 15....how to fix
- gauge cluster?? help wanted!
- Heat Shields
- A/c rattle??
- Factory gauges?
- How to make an LT1 work with a 1981 Camaro
- 5.0 vs LT1 vs 400
- Do I need a new window motor AND regulator?
- how to replace the radiator core support ?
- Wheel noise or rearend going out?
- electric supercharger
- vibration after 90mph
- A/C issue, guage said low, now says danger!
- Dash Harness...
- autometer
- Stupid Questions Probably but....
- Deal of a lifetime.
- pos headlights
- tb bypass coolant connecters
- Mystery Part....
- door lock/unlock button wont work on both sides
- Where is the parking lamp relay???
- Where is the window relay?
- Replacing Transmission mount and Torque Arm Bushing .
- Vacuum Caps - What size for air/K&N?
- plug wire set help
- Where To Buy A/C O2 Sensors
- Turn Signal Issues
- 95 camaro TCS disable switch Schematics?? Lost mine...
- power window motor help
- Broken Hand Brake Handle
- Frozen Trip Odo
- Quick Antenna question...
- Hood vents on a stock 93-97 hood
- Code Scanner advice
- Random ?
- Passenger Sideview Mirror
- Another power window problem!
- Convertible top fabric peeling from window
- Horn quit working, any ideas?
- Alt. belt noise
- security light
- uh oh, big cloud of freon, A/C gone
- Using Camaro lighting harness with Trans Am?? Possible?
- Powdercoating Service?
- help troubleshoot starting problem
- Good Price?
- MAF sensor getting 0 volts.
- What should the high/low side pressure read...
