Temp cooling fan(s) should come on?
Old Jul 18, 2007 | 06:26 PM
snowman43's Avatar
Hello,
First post here, bought a '94 Z28 last Thursday. Seems to have run cool (190-195 ish) until tonight. Now it wants to climb in temp sitting still, comes down in temp while moving. Doesn't appear the fans are coming on, wondering if anyone knows what temp the fans typically come on, what triggers them and where they get their power source? Swapped relays around and changed nothing...
Thanks in advance,
Brian
Old Jul 18, 2007 | 07:02 PM
JAB's Avatar
JAB
I believe the stock turn on temps are around 212 and 224 or so. These are warm running motors. The PCM commands them on via the signal it's recieving from the ECT in the water pump. They also come on when you turn on the A/C.
Old Jul 18, 2007 | 07:04 PM
Here is some reading about the cooling system.
Old Jul 18, 2007 | 08:16 PM
snowman43's Avatar
Thanks for the replies. Looks like I may have jumped the gun a bit, fans do come on but coolant temp has to reach 225-230, higher than I had expected. I didn't let it get that high earlier to see the fans cycle.
Excellent article shoe, bookmarked it just in case...
Thanks again,
Brian
Old Jul 18, 2007 | 08:18 PM
96 Z 28's Avatar
PS changing to 160 Deg T-Stat is also pretty helpful in keeping temps down, although to get the best benefit you need to also have tuning done.
Old Jul 19, 2007 | 11:06 AM
oneclean97z's Avatar
in no way trying to thread jack but in shoebox's writeup posted above it is saying that fans on while on the highway can alter the cooling capabilities? is this true cause i have noticed a few times when my fan switch is on on the highway it will get hotter than driving around the regular streets and neighborhoods
Old Jul 19, 2007 | 01:09 PM
CaliChevyLover's Avatar
my bro had this problem w/ his 3rdgen formula.
is ur fan belt driven or electric? if its electric u can install a kill switch on the center console or somethin..and u can turn it on and off at will. the prev. owner of my iroc put one of those in.
timmy39120
May 8, 2015 11:41 AM
LingenfelterZ28
Apr 25, 2015 10:24 PM
LingenfelterZ28
Apr 24, 2015 02:00 PM
Biggiebound
Apr 23, 2015 08:50 AM
grabbem88
Apr 16, 2015 06:57 PM
