High Beams on 1997 Z28 Don't Work
Old Jul 18, 2007 | 11:18 AM
Bowen292's Avatar
They worked fine about 6 months ago, then they would randomly "fade" in and out while i was driving.... like kinda as if i was flashing someone but still stay predominately on.... and now they just flat out don't turn on.
Notes:
-The High beam light in my instrument cluster would come on if they were actually on, and yes now that doesn't come on either obv.
-I did install Hella FF75 headlights for my high and low beams.
-Lows work Fine, have never had a problem with them.
-I am running 55watt bulbs in both low and high.
-Fuses and relays are fine.
-I read somewhere that the stock wiring can handle like 85 watts, and my lows still work fine, so this would lead me to believe its not a wiring issue.
I was thinking it could be my actual high beam switch/trigger on my steering wheel column. That might describe why the lights started to fade on and off b4 they stopped working completely.
Any ideas?
If it is the switch/trigger on the steering wheel column, is that easy to fix? It honestly doesn't look it.
thanks
Old Jul 19, 2007 | 12:57 PM
NEWBIE T/A's Avatar
Thumbs up Shoebox's site will once again save the day !
You should save this as a favorite !
http://shbox.com/1/4th_gen_tech1.html
See item # 83 for the dimmer switch - located at the bottom of the column.
Try working it manually ( it's a click switch ) , and if the high beams come on, the the switch is out of adjustment or there is an issue w/ either the actuator rod, or the black plastic piece that rides on top of it inside the housing cap ( the cap is # 25 ) in the column.
Tearing into the column is not hard if you have the proper tools to remove the steering wheel & lockplate - if not, it's a wee bit tricky , and strong thumbs from a helper will be a big plus for the lockplate removal.
Good Luck !
Britt
Old Aug 28, 2024 | 07:04 AM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Re: High Beams on 1997 Z28 Don't Work
You might have corrosion in the high beam sockets.
Old Aug 28, 2024 | 07:29 PM
NEWBIE T/A's Avatar
Smile Re: High Beams on 1997 Z28 Don't Work
Hopefully after 17 years he got it figured out one way or the other !
Old Aug 28, 2024 | 09:05 PM
He's playing some sort of head game. Thinks it’s cool to dig up three or four of these 20 year old threads each day and post a very brief, superficial response. Unfortunately he posts erroneous info from time to time, and I try to correct it so it doesn’t mislead someone using the “search” function.
Might start deleting his posts and if that doesn’t work, close his account - maybe somebody hacked it.
Site has gone down fast, but no excuse for BS.
ADMIN
Old Aug 28, 2024 | 09:24 PM
SteveC's Avatar
Thumbs down Re: High Beams on 1997 Z28 Don't Work
ADMIN
I am sorry you feel this way about my posts, I am just trying to contribute to this once great forum. Nothing gained, nothing lost.
Old Aug 28, 2024 | 09:51 PM
What contribution do your posts of erroneous info make?
Please grow up.
ADMIN
Wicked 97TA
Nov 7, 2009 06:46 AM
scmudslinger
Aug 7, 2005 01:23 PM
greensmoke
Mar 22, 2004 04:42 PM
94BlackBowtie
May 13, 2003 02:20 PM
joecarrr
3rd Gen / L98 Engine Tech
Dec 29, 2002 07:14 PM
