Heater Core replacement 1995 Z28 ?
I had to do this last winter here is my Thread: http://web.camaross.com/forums/showthread.php?t=495890
Basically ,
1. Remove Glove box
2. Remove two screws holding heater core cover and carefully move it out of the way with wire attached .
3. There is one screw holding the heater core remove it .
4. Under the Hood , Disconnect Both Hoses and theres a clip holding the two pipes of the heater core on the firewall it has a screw holding the clip in ,Remove the screw and clip .
5. Wiggle it out , Its tight but it comes out . and reinstall your new heater core .
p.s. make sure you did not knock any vacum lines or wires off .
Basically ,
1. Remove Glove box
Jan 5, 2015 07:14 PM
