code 15....how to fix
i got a code today after starting the car for the first time in a week or so.
15 Engine Coolant Temperature (ECT) Sensor Circuit (signal voltage high, low temperature indicated)
we just rerouted my plug wires, and changed out my accessory bracket, so what could have caused this code to come up, how do i fix it?
is it possible that the coolant is just low? My car is still too warm to go check
The low coolant sensor would have nothing to do with it. The temp sensor on the water pump is easily reached from underneath. Make sure you did not smash the wiring with the accy bracket install.
well, i believe i do have a problem with the wiring somewhere making it not read right, which is also making my car hard to start. Just gotta try to hunt it down now i guess. If its the sensor itself, what does it take to replace it?
You just unscrew the old one and screw the new one on. Do it quickly because you will lose coolant out the hole. Make sure before replacing it that you didn't bend the pins in the connector. I did this once and it wasn't getting a good connection.
http://shbox.com/1/temp_sensor1.jpg
1996LT1Z28
Apr 14, 2015 07:15 PM
