Should I install new plugs & o2s with header leaks?
Old Jul 4, 2007 | 05:48 PM
JJJ93z's Avatar
I just got my gmmg free of leaks, however I still have leaks on the header gaskets (even with Breslin locking bolts). My 02s a shot and its missing pretty bad. However I am going to be doing a heated o2 conversion as well as switching out the plugs because they are most likely fouled.
My question is will the o2s and plugs foul out again if I have a header leak? I know I should get the header leak fixed first, but I am limited on time and garage space. Any opinions would be appreciated!
Also are there any better locking header bolts out there then Breslin? They are just a pain in the Azz to tighten because of their design. Thanks
Old Jul 5, 2007 | 12:08 PM
96ZCamaro's Avatar
You should fix header leak first. Fix it right the first time or dont do it at all.
Old Jul 5, 2007 | 02:56 PM
95LT1conv's Avatar
what are you using for header gaskets? I used arp 1" stainless bolts w/ 5/16" head and lock washers. The smaller head is great for using box end wrench.
Old Jul 5, 2007 | 05:35 PM
Fix the leaks.... they are hurting your performance.
Have you checked the header flanges to make sure they are flat? If they aren't they may never seal correctly.
Old Jul 5, 2007 | 05:56 PM
JJJ93z's Avatar
95LT1conv Im using Percys aluminum gaskets http://store.summitracing.com/partde...5&autoview=sku
and Breslin split locking header bolts http://store.summitracing.com/partde...4&autoview=sku
which Summit apparently doesnt carry anymore.
Are those ARP bolts you have sold as actual header bolts? Or did you just specify depth, thread pitch, ect.? I am ready to ditch my Breslins, did your setup ever come loose on you?
Injuneer- youre definitely right, shes running terrible now. And I believe I checked the flanges when I first got them b/c I had to send back the 95+ emissions ready LTs and wanted to make sure everything was right on the offraod LTs I Originally ordered. When I get back from my business trip next week I am going to tear em off and check for trueness. Any tips on that without taking them off the car? I was thinking about getting a piece of 1/8-1/4" aluminum and holding it next to it.
Old Jul 5, 2007 | 09:26 PM
95LT1conv's Avatar
http://www.jegs.com/webapp/wcs/store...44888_-1_11539
070-400-1109 part #
with these washers
http://www.jegs.com/webapp/wcs/store...48863_-1_11539
Old Jul 6, 2007 | 03:39 PM
You need to take them off and hold a good metal straight edge, or aluminum level against the face of the flange. I got my AS&M headers used from a friend. He checked them when he bought them and they needed to be planed to be true. I installed them 7 years ago, with the Mr. Gasket Ultra-Seal copper gaskets and ARP header bolts, and they have never required more than a quick check and a minor turn of the wrench every 6 months or so.
Old Jul 13, 2007 | 09:36 PM
JJJ93z's Avatar
Originally Posted by 95LT1conv
Are you running the washer that came with the bolt and the lock washer as well? Also did you take use of the holes for safety wire? I think Im going to pick these up and ditch my 12pt breslins, that hex head looks really easy to turn on the ARPs
dmcdonald96
Jan 30, 2015 06:46 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
GigaMp3z
Feb 20, 2003 02:57 PM
CobraEatr
Jul 23, 2002 06:32 PM
