4th gen door pins replaceable?
wind caught my door hard saturday and noticed that it is now rubbing the at the front fender when it is opened, but not when it is being closed.
i think that the hinge is possible bent a couple of mm on the top, so this could be the problem. BUT, i noticed that the bottom pin on the bottom hatch is loose, and actually spin when the door is opened. the rest of the pins do not spin so i assume they should remain stationary?
i have noticed that the door has been sagging a small bit so do you think that the wind just finished it off.
are the pins replaceable and what would i need to do it. or is this a waste of time and i need to look into a new hinge?
thanks, critter
thanks, critter
Jul 4, 2005 05:00 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
