Loosey-Goosey Turn Signal
Old Jul 21, 2007 | 08:38 PM
Laymaster's Avatar
Hey Guys. For a while now I've had a loosey-wobbly turn signal. Basically when the turn signal auto-cancels after a turn, it half-connects and makes the left turn signal and the turn signal (on the dash) lights up dimly, but does not blink. If I touch it (lightly up/down) it wobbles a little bit. Anyone know what you need to do to fix this? New parts or just a little adjustment? Thanks.
Old Jul 21, 2007 | 10:51 PM
Sounds like you need a new lever or a new switch in the column.
Old Jul 21, 2007 | 11:02 PM
Laymaster's Avatar
i guess that's one you don't have a how-to for? is it involving or like a 5 minute deal?
Old Jul 22, 2007 | 07:45 AM
Sorry, no how to, but it will be more than 5 minutes. The MFL just pulls out (after you disconnect the cruise wiring plug). Getting into the column is more involved.
Old Jul 22, 2007 | 09:14 AM
Laymaster's Avatar
MFL? No fun there!
Old Jul 24, 2007 | 09:52 AM
NEWBIE T/A's Avatar
Smile It COULD BE a loose screw ...
Where the metal arm attaches to the turn signal switch .
But, you still have to get into the column to access it.
Not hard w/ the proper tools - a real PITA w/o , and a real possibility of damage to the column as the shaft is designed to collapse, and methods that involve beating on or pulling on the wheel by hand can cause damage.
Fortunately, the tools are relatively cheap & are probably at your local parts store.
Britt
Old Jul 24, 2007 | 02:33 PM
Laymaster's Avatar
what tools do i need to get in there?
Old Jul 24, 2007 | 02:50 PM
NEWBIE T/A's Avatar
You will need a steering wheel puller & a lock plate puller.
This is an older column, but gives you an idea:
http://www.buickperformance.com/tilt...lumnwobble.htm
You won't have to go nearly as far into it as this shows.
Hope this helps !
Britt
stangspank
Nov 13, 2015 01:02 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
