How did you wire your manual fan switch?
Old Jun 30, 2007 | 12:49 PM
The Captain's Avatar
Well, how did you wire up your manual fan switch? I was thinking about just running +12V to the fan, and putting my switch in between the ground. Any suggestions?
Old Jun 30, 2007 | 01:20 PM
Bad idea, IMHO. Easier, better to use the relays that are already in the fan circuit.
http://shbox.com/1/fan_sw_diagram1.jpg
Old Jun 30, 2007 | 01:29 PM
LOW TRAC's Avatar
Those are the instructions I used to wire my 94, seemed to work fine. I just had the low speed over ride for when it was sitting at the track or something, course they're quiet enough at that speed that you might leave them on all night. Not that I know of anyone that might have done that.
Old Jun 30, 2007 | 02:47 PM
so basically I am just grounding the green and blue wires, correct?
Old Jun 30, 2007 | 02:52 PM
That is right. You are simulating what the computer does to turn on the fans.
Old Jun 30, 2007 | 03:07 PM
mdacton's Avatar
just running the 2 wires to either side of a switch? thats it?
those wires go to a rela correct? so there is no need to add a 12v or ground?
Old Jun 30, 2007 | 03:17 PM
No, you splice in to those wires, and ground them. This energizes the relay, which turns on the fans. At least thats how I have come to understand it.
Old Jul 2, 2007 | 11:22 AM
Anyone care to elaborate on this?
Old Jul 2, 2007 | 01:27 PM
That's what the schematic shows.
Old Jul 3, 2007 | 01:31 AM
theratdude64's Avatar
So this way You can manually turn them on, but the switch in the off position is normal operation? I want a way that I can manually kick em on, but not 100% manual. My friend had 100% manual fans and I just know my dumbass would forget to turn em on sometimes
Old Jul 3, 2007 | 07:35 AM
The diagram shown operates the fans just as you say. It gives you manual override, but allows normal, computer controlled operation with the switch not engaged.
Old Jul 3, 2007 | 02:07 PM
qboneus's Avatar
Is this the same for OBDII as well?
I wouldn't mind adding this to my Z
Thanks,
Tal
Old Jul 6, 2007 | 02:22 PM
BMoney's Avatar
not to try and hyjack this thread, but I did the same thing on my 96 Formula. I spliced in to the blue high speed wire, and only 1 fan came on! is one fan high speed, and the other low speed? thanks
Old Jul 6, 2007 | 02:32 PM
Thanks,
Tal
Slightly different schematic, but basically the same.
Old Jul 6, 2007 | 02:33 PM
That is because the way the relays and fans are wired. All 3 relays must be operated for both fans to run at high speed. If you can read a schematic, you will see why.
