Where is the window relay?
Where is the power window relay for the driver side on a 96 Formula? I can hear in the dash, but couldnt find it going up through the bottom. Is it way up behind the cluster or something?
What you might be hearing is the express down module. If you can hear that and the window is not working, it is usually because the window motor is bad.
sounds more like a window motor starting to go, I've had them do that before and it finally gave out. the express down module that shoebox mentioned is kind of burried in all of the wiring to the right of the stearing column under the dash, if it's still clicking and making a weird noise then it's still good. I also made the mistake of replacing it and the window seemed to work better for awhile and then the motor died.
Aaront810
Aug 29, 2020 09:34 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
z28cam1993
Sep 9, 2015 04:08 AM
