A/C system question
A/C system question
alright, couple months ago, my AC had a "AC pressure sensor low" code come up, and i would reset it and it would come back. My Compressor will not turn on for me to charge the system up. We called the shop that origionally changed out the whole A/C system and he said that i have to "turn it on in the computer". How do I go about doing this, and is this even correct?
alright shoebox, i did it when the car was off and it made no difference, then i tried it with the car in the accessory mode when your radio wil come on and still made no difference, so do i do it when the car is running or what?
well, if the a/c pressure is low, it will set that code immediately , so, the system needs to be vacuumed down, then the system partially charged, , then reset the pcm with the fuse trick, then it should work
or the compressor relay can be jumped to get the system charged, then the reset can be down
I got no A/C either. I jumped the relay for a couple of seconds just to verify the compressor would run. Underhood relay box - B1 ->B4 on the A/C relay triggered the compressor on mine.
Haven't gone any further though.
