door lock/unlock button wont work on both sides
Old Jun 18, 2007 | 01:44 PM
afr lt1's Avatar
My lock/unlock switch on both doors wont work. I read in the manual that the key has to be in....well that doesn't make any difference, it still wont work. The switch makes no noise what so ever when pressed in either direction.
-it worked fine for the first few yeas of owning it, then at some point it stopped.
Also, my key fob unlock/lock buttons dont work hardly at all. My driver door will unlock after I press it like 5 times(but wont lock). The passenger side will only lock when I press *unlock*.... I know that sounds weird, but that is what it does.
Thanks in advance.
Old Jun 18, 2007 | 11:23 PM
Compstall's Avatar
Follow the electrical schematic to where the switch wiring for both sides meet. Find something in common with both sides. I don't have access to my schematics right now or I'd be of more help.
As far as the key fob goes, have you tried swapping in a new battery?
Old Jun 19, 2007 | 08:33 AM
afr lt1's Avatar
yup, i have tried new batts. I also tried two different key fobs and they give the same result.
Old Jun 19, 2007 | 09:30 AM
Lunch Box's Avatar
The contacts for the buttons on the key fobs can get gunked up over time; you can clean them with the hard pink pencil erasers; although your problems might be more than that
Old Jun 19, 2007 | 01:03 PM
afr lt1's Avatar
nope, it has nothing to do with the key fobs. I do hear a little click from under the glove box when I press the button and nothing happens.
Old Jun 20, 2007 | 12:53 PM
afr lt1's Avatar
bump. has this never happened to anyone?
Old Jun 20, 2007 | 04:42 PM
Critter's Avatar
mine started doing it 2 days ago. i think it has somthing to do with the friction on the driverside locking mechanism. take off the door panel and try it see if it still sticks, then if it is see if there are any areas that are rubbing more than normal and lube them.
Old Oct 29, 2007 | 02:35 PM
afr lt1's Avatar
new ?
Will both sides stop working if the drivers side switch is bad? OR is it only the passenger side switch that stops both sides from working?
Old Oct 29, 2007 | 04:53 PM
Critter's Avatar
if one switch goes out the other will still work. i took my panel off and made sure everything was lubed up and it works fine now.
Old Nov 1, 2007 | 09:07 AM
afr lt1's Avatar
NICE! I finally discovered the prob. I found a broken grey wire in the boot at the hinge of the driver side door. OMG, I cant believe I didn't find it sooner.
ALL IS WORKING!
Old Nov 3, 2007 | 09:30 AM
Critter's Avatar
ALL IS WORKING!
makes life a lot better huh.
DirtyDaveW
Dec 1, 2016 05:37 PM
Rod Bender
Jan 1, 2015 03:18 PM
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
tds1213
Nov 27, 2014 12:55 PM
siguy
Nov 27, 2014 10:07 AM
