Cooling fans restricting air flow 45 MPH and up !!!!
Old Jul 17, 2007 | 11:06 PM
AZ2ENVY's Avatar
Ok I had my PCM tuned my ION@MADZ28 . Well i chose to have the cooling fans come on at a lower temp than stock . Well this is my problem ....
The car runs cool and just fine in town driving (anything
40 mph or below) . When the car is moving 41 MPH and
up while the cooling fans are still on they (cooling
fans) become a restriction to airflow causing the
car to heat up more than usual . My Cooling fans are
staying on at 41 mph and above because the PCM sees
the coolant temp not dropping (caused by the fans
on at highway speeds) . I need the fans to turn off
while at highway speeds so the car doesnt heat up .
Am I explaing myself correctly ? cuz my point is If the
Cooling fans are on high at highway speeds they become
a restriction to airflow getting to the radiator to cool the car down .
Old Jul 17, 2007 | 11:10 PM
bdc95ta's Avatar
You think theyre that much of a restriction? They're behind the radiator?
-b
Old Jul 17, 2007 | 11:14 PM
AZ2ENVY's Avatar
Yes because the fans can pull only so many cfm's while on the high
setting . There is more cfm's of air coming into your radiator at highway
speeds than the fans can pull through . so the air doesnt get pulled through
the radiator cuz the fans are acting like a wall keeping fresh air from getting through .
Old Jul 17, 2007 | 11:24 PM
How do you "know" they are a restriction? Maybe you have an air dam problem. That would be more common.
Old Jul 17, 2007 | 11:29 PM
thesoundandthefury's Avatar
You wouldn't happen to have ground effects would you? Are you lowered? Both?
Old Jul 17, 2007 | 11:31 PM
Danny McAdams's Avatar
I don't think the fans are your prob., be sure the AC condenser and front of radiator are not dirty, a plastic ice bag got me on the interstate once, don't take much to get too hot. Danny Mc
Old Jul 17, 2007 | 11:40 PM
AZ2ENVY's Avatar
The car is in perfect shape and brand new air dam . You can actually
see a temp difference when the fans arent on at highway speeds .
Old Jul 18, 2007 | 12:01 AM
AZ2ENVY's Avatar
Hey do you guys think this could be contributing to my highway
cooling issues ???
Old Jul 18, 2007 | 12:29 AM
AZ2ENVY's Avatar
Here is the piece thats missing from the first pics i posted . This plastic
shroud encloses the radiator from the engine bay . I removed it and didnt put it back in thats why you can see the trans cooler and radiator when the hood is popped .
Old Jul 18, 2007 | 12:35 AM
speed_demon24's Avatar
cooling issues ???
Yes
bdc95ta's Avatar
Is there a gap for the trans cooler? Do you have an oil cooler up there too?
Old Jul 18, 2007 | 12:36 AM
AZ2ENVY's Avatar
Yep theres a gap for the trans cooler about 1/4" actually
Old Jul 18, 2007 | 12:38 AM
AZ2ENVY's Avatar
Originally Posted by speed_demon24
Yes
Thank you
Old Jul 18, 2007 | 07:32 AM
See, it is not your fans at all. You removed an important piece that directs the air to the radiator. It's the same as removing the air dam.
Old Jul 18, 2007 | 07:54 PM
AZ2ENVY's Avatar
It didnt dawn on me till the last minute that i left that piece out
