Oscillating A/C
Old Jul 1, 2007 | 05:59 PM
KYWes's Avatar
Oscillating A/C
'95 Z28
At idle my A/C cycles on and off and it never gets cold enough. At highway speeds it will cool. I have been told the expansion valve is bad.
Anyone confirm this? Anyone able to share on how to replace the valve.
Old Jul 1, 2007 | 06:58 PM
n2ceptor's Avatar
1. Have you had the system check on pressure readings??? Might be low on freon...
2. You might be talking about the expansion valve??? Its located passenger side by firewall... And yes it might be the problem...
3. If the expansion valve is the problem, also replace the accumulator/dryer...
http://shbox.com/1/ac_system.jpg
Item 22 expansion valve
Item 12 dryer/accumulator
Picture courtesy of Shoebox...
Old Jul 1, 2007 | 09:22 PM
KYWes's Avatar
Whoops, I did mean Expansion Valve.
Thanks for the diagram.
I'm guessing this repair will require pulling a vaccumn and recharging after replacing these components.
Am I correct that the expansion valve is tucked under the cowl making it difficult to get to?
Old Jul 1, 2007 | 09:42 PM
n2ceptor's Avatar
Not really, but I took mine to a reputable shop with parts in hand and had them install/flush/vacuum/recharge the system....
But I used this freon;
magman
Apr 15, 2016 03:08 AM
WPHIG2
Aug 27, 2015 06:37 AM
MikeWhitener
Aug 2, 2015 06:17 PM
timmy39120
May 8, 2015 11:41 AM
Chuck!
3rd Gen / L98 Engine Tech
Jul 18, 2002 03:30 PM
