vibration after 90mph
Old Jun 19, 2007 | 08:32 PM
got_hp?'s Avatar
finally got my car tuned so im actually driving it a bit, but after doing a few pulls i quickly found a bad vibration (shakes the whole car) at about 90-95ish.
its not engine related, just speed.
i doubt its the driveshaft since that was balanced at a driveshaft shop before i put it on.
tire pressures are all ok.
what are my other usual suspects to check?
wheel bearings?
would like to try and narrow it down so i dont have to just throw parts at it until i find the problem.
any ideas are appreciated.
Old Jun 19, 2007 | 09:10 PM
8cylinders>4's Avatar
pinion angle?
Old Jun 19, 2007 | 09:45 PM
reamo04's Avatar
loose lugnut? Can you tell where the vibrations coming from?
Old Jun 20, 2007 | 12:25 AM
got_hp?'s Avatar
not really........the whole car shakes, lol
ill check the lugs tomorrow, it has been sitting for a while so its possible.
Old Jun 20, 2007 | 12:49 AM
Danny McAdams's Avatar
Make sure the u-joint caps are properly seated, DS makes a hella of a mess if you throw it out of the saddles. Danny Mc
Old Jun 20, 2007 | 06:26 AM
afr lt1's Avatar
After you check everything else, I would say throw in the aluminum 1le driveshaft. I picked one up off of ebay from a junk yard for under $100.
Old Jun 20, 2007 | 06:47 AM
JakeRobb's Avatar
Super Moderator
Tire balance? Front end alignment?
Old Jun 20, 2007 | 10:09 PM
Switchblade's Avatar
I would check pinion angle and the motor mounts.
autoxr166
Sep 25, 2015 04:21 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
Apr 16, 2015 09:57 AM
