95 Codes
Old Jun 22, 2007 | 03:31 PM
theratdude64's Avatar
95 Codes
I did some searching and found this on Shoebox: http://shbox.com/1/dlc1.jpg and I'm confused. I know that on older OBDI style connectors you jump B and A to get the check engine light to flash the codes... And I figured that looking at this I could finger it out. Not so much...
Which do a Jump? My stupid car decided to throw a Check Engine light on my birthday It runs totally fine, so not sure what it is. But yeah. Did OBDI have the Fuel Cap Pressure code in it? I went to the gas station and it wasnt on, then I pumped gas n got in and it was on. Most likely just a weird coincidence
Old Jun 22, 2007 | 03:40 PM
JAB's Avatar
JAB
You can't jump a 94 or 95. Only the 93's.
Old Jun 22, 2007 | 04:09 PM
reamo04's Avatar
you can buy like a 30 dollar "code puller" from oreillys that works pretty decent
Old Jun 22, 2007 | 04:12 PM
2001NBMZ28's Avatar
'95's are ODBI w/OBDII connectors - so make sure it'll work on your car.
Old Jun 22, 2007 | 04:59 PM
$30 code pullers are usually glorified paper clips that do nothing more than short the pins. As already noted, that only works on 1993s.
Old Jun 22, 2007 | 06:34 PM
so theres no real way to pull codes on it? Weird.
Well, the light went off lol. But still good to know
Old Jun 22, 2007 | 06:39 PM
2000GTP's Avatar
You can still pull the codes, but you will need an OBD-I scanner with an adapter to work with your year car.
Old Jun 22, 2007 | 08:56 PM
droptop z's Avatar
Get a obd1 scanner, along with the obd1 style pin connector, this is how you jumper the pins.
http://shbox.com/1/xraycable.jpg
Old Jun 22, 2007 | 09:01 PM
Cant just Paperclip Pin 9 and 5? Does that scanner actually read it or just make the light blink like OBDI usually is? I'm confused
DAMN LIGHT CAME BACK ON! Now the low coolant light is on but the Coolant level is fine, I opened bleeder screws, checked over flow... its fine Stupid car, just HAD to pick today to give me all this crap
Old Jun 22, 2007 | 09:06 PM
This isnt enough of a "scanner" is it? I have one of these glorified paper clips... came with one of my 3rd gens I had a while ago
JAB's Avatar
JAB
The low coolant level sensor gets dirty easily. Most people just unplug it and then keep track of coolant level.
Old Jun 22, 2007 | 10:45 PM
If it has no readout of its own, it will not work. Gotta have a real scanner. No blinking lights past 1993.
Old Jun 23, 2007 | 06:21 AM
No, you can not.
Old Jun 23, 2007 | 10:19 AM
droptop z's Avatar
This is the one I bought, Actron 9150
http://cgi.ebay.com/ebaymotors/ACTRO...ayphotohosting
Old Jun 23, 2007 | 05:28 PM
ah that sucks. But now I know lol. My car is just bein all squirly, i duno what its deal is. no drivability issues though lol
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
