View Full Version : LS1 Based Engine Tech
- 440+ rwhp, NA, stock block
- spun bearings and oiling problems with heads/cam
- T/A headlight problem....
- Are MAC headers for a Camaro and a SS the same?
- vortec coils work on an LS1?
- dyno #'s
- Fuel Injector Question
- 02 simms
- Automatic Tranny Fluid in an M6?
- 18x9.5 verse 18x10.5
- Make my Car Fast as Possible w/ this Budget
- Removing cats
- spintech exhaust
- Weird noise from under the hood. What could it be?
- Loss of Power?!?!?!?! WTF!!!
- Jumper cables in your SS?
- First DYNO experience on my 01 Z28...Results in my sig.
- Harsh 1-2 shift
- Vapor Canister
- Price for a new cam install
- synchros
- Intake manifold fittings (throttle cable bracket)
- Mcleod Adjustable Clutch Master Cylinder
- New holly intake for LS1
- Making an LS1 faster than a Z06
- port and polished LS1 heads
- Is it possible??
- Lowered Susp. 00 Z28 questions
- Engine Mods: Possible to do w/out pulling motor?
- Need info on 4:10 install
- which rear end fluid to use?
- ..power gains from headers...weak or strong?
- SLP 1.85 rockers
- DMS spring installed
- shift knob size
- Shift Light Question
- G2 Strurt Tower Brace
- Should I Put Jounce Jumpers Back In?
- Tune up after Cam install?
- Hooker LT's & Mufflex Y Pipe Fitment Issues?
- SLP LT headers and SES light???
- exaust tone websites
- lt1 t56 swap with ls1 t56
- Ls1 Q
- 1 quick converter ?. please help
- Exhaust tones
- Removing Brake Caliper Question
- Question's about exaust?
- How Many Times Can I Resurface My Stock Flywheel?
- How Hard Is It To Install A Walbro 340 In A 1999 Ta
- Rattle Noise Under Car
- Oil Pressure
- Using gm top end cleaner...wheres the air diverter valve selenoid???
- Direct Flo Lid
- Too much oil pressure???
- Getting Off The Line Quick
- Just a little tidbit on changing rear bulbs on Camaros.
- 98 Camaro Z-28
- newbie questions
- Can someone tell me the paint code for the Black 1998 to 2002 camaro
- Electric water pump or Underdrive pulleys?
- Help Putting on New Rotors
- ss and z28 - help please
- ? on brakes.......
- how well can a stock LS1 handle a supercharger?
- Need QUICK Info About DriveShaft!!!
- torque strap?
- LS1 engine problems (fuel, idle, backfire)
- To those that have LM or DM exhaust
- Anyone want Autotap?
- How do you Eliminate Governor?
- 98 LS1(a4 2.73) vs (a4 3.23) vs (m6 3.42)
- some LS1 questions
- I'm pretty sure oil from PCV is causing my misfire! What should I do???
- My DRL is messed up!
- LS1 Edit
- custom CAI
- I JUST BOUGHT A 2000 SS!!!!
- Who has Eibachs with KYB AGX shocks??? Thinking about buying the KYB's...
- Loud clicking from rear hatch!
- LS1 Head Gasket Question
- J & E Performance 98 Turbo Camaro 8.12 !!
- Driveline Effeciency
- Bra is a PITA
- Bad Speaker
- Swapping v6 with LS1
- Faint Humming/Chime Sound in Hatch
- Anyone have .224 .224 / .581 .581 114 cam?
- True Dual Question
- 17's in front and 16's in the back...possible?
- how much will it cost to get a ss hood painted?
- Ever heard of Microtuner by Superchips?
- 1 in 2 Magnaflow muffler
- supercharger question
- Pics of my New Car :)
- which ls1...
- anyone have pics of a metalic green 98
- ls6 intake
- Saw this on Corvetteforum.com about a PCV oil filter "mod"
- Does 3" exhaust pipe sound much different than if you use stock 2 3/4"?
- Idle speed?
- horn constantly blowing
- tsb's?
- Best Brake Upgrade?
- Why is my trap and et low?
- T56 question
- Fuel Filter and STP Injector Cleaner
- Predator ?
- What mods/power is needed to lift the front off?
- LS1 Head Gaskets
- Governer bypass
- Valvoline Motor oil
- Prepare for a 03 Cobra Race, need help...
- Red Line Oils
- grinding
- To anybody who has dropped there crossmember:
- Obnoxious
- throttle body?
- ls1 probs please help
- Pics of SLP SFC´s?
- Brake Rotors
- Brake question
- cam choice for a4 with nitrous
- ls1 into an lt1 f-body
- What gears?
- HELP!! power steering died in a donut
- Did I make the right choice?
- Does anyone Camaro pull to the left...even after alignment..
- Deep Cryogenic tempering????
- problem with my car.....help???
- Removing front grille
- How do I remove my A4 Shifter?
- Dyno Techs or Thermo inclined people IN HERE PLZ
- Jet-Hot LT Headers on the way!!
- Holy S#!t
- How to get center console off?
- New to the LS1 world
- Injector Q:
- Rear Suspension/Panhard Rod Question
- Short Stick help!
- Dyno results from my TR220 cam swap!
- LS1 Tech
- Air box
- Question?
- Guys with MAC midlengths, i need input
- Cold exhaust 'pop' sound
- Life of Stock Clutch?
- colored bellows?
- Low Idle on 00 Z28?
- 1le?
- Value of complete LS1 shortblock with heads??
- LS1 lids-I don't get it?
- Cutout Problem?
- Ported Maf Ends
- McLeod Rev-Lok II Help
- Limited slip additive + Moser = :)
- Headlight not opening on TA
- wanted; 98-02 for exhaust fit/testing
- Turbo Tune in greensboro Nc??
- Alternator Question?
- selling 02 Z28
- Dynomouth exhaust
- how long will rear end last???
- Mix and matching springs......
- Interior Lights stay on.
- ls1 white
- Motive or Strange gears???
- Power...blower,or CAM Package
- 3200 on 98 SS
- Is $18,995 a good deal??
- Anyone using the Baer GT+ kit with 17x9 ss wheels?
- regarding Speed inc.
- best catback
- Any HP gain from free-flowing muffler?
- Car Lights
- hypertech
- ARE high flow fuel pump
- P1153 code
- the right exhaust
- losing power
- IAT Sensor for Lid???
- newbie with question
- B&B Triflow clips!
- For those who have the BMR Adjustble torque arm.....
- Panhard bar and how to adjust it.....
- What can I build an LS1 for?
- Is $12,900 a good deal for a 98 Trans Am?
- For all you Corsa owners?
- Fuel Gauge Woes
- air lid
- B&B Triflow
- 98-00 vs. 01/02
- What to get to reprogram speedo???
- slight vibration in pedal?
- engine temp?
- How much hp?
- mac headers
- thinking about trading my 93 TA in for a 98 TA. opinions please
- SLP loud mouth...
- Anyone have info or a link to a cavaliers brake system diagram?
- LT1 or LS1. which one to mod
- Cut Out Noise
- Does anyone have their heads off thier car or...
- What other mods can i do....
- will my tranny go with a 9 inch moser?
- What starters fit LS1 engines? LT1 or?
- Installed shifter yesterday, noises? clutch/flywheel??
- What are Codes?
- 2.73 vs. 3.23 vs. 3.42: Differences?
- Another newbie question
- Introducing the Austin Bellows: Looks great with no ribs. Pics inside
- Broke an intake bolt..please come in
- What Mods Next?
- Car Revving Problems
- Ok, I need some help-00 OR 01?
- Most refined sounding exhaust?
- Gas gauge problems
- A4 sign of going bad?
- how to do a brake pad change??
- 1.8 rollar rockers?
- Removing Ram Air baffles?
- First Time Dyno!!!
- PO420: Catalyst Efficiency below theshold...
- Wanting to know...
- hp gain with hooker LT and cat back
- Brake Rotors
- lowering ? need a lot of info
- For those of you with 17x11 in the back
- So close but so far away!!
- What would a 98-00 LS1 (TA) W/full exhaust & CAI (lid) DYNO??
- 3.73 or LT headers and WARRANTY?
- t-56 problems help
- MY caliper came loose while driving!!
- question about uploading a tune!!!
- do all camaros come with aluminum driveshafts?
- how much oil to put in ls1
- Buying gears need help
- Firestone Firehawk SZ50 EP users inside...
- Gears or wet sand?
- is gmmg chambered. louder than borla?
- To cat or not to cat.. that is the question
- Tighten NGK tips?
- Rear from a 95 z
- Idle re-learning procedure...
- Will I dyno less power with these wheels??
- Need Help
- need advice
- I think I need new tires, suggestions?
- Oil Change Light (?)
- 01 ss exhaust ? (corvette sound)
