SLP LT headers and SES light???
Old Apr 3, 2003 | 06:00 AM
hrtbeat2's Avatar
Angry SLP LT headers and SES light???
I just install SLP LT headers with their high flow cats and y-pipe also, everything by them. I put on about 50miles or so and the SES light came on??? It runs find, I do smell alot of exhaust fumes, a friend of mine said it could run to rich and I could install a Mass translator to my already Mass air meter by SLP to lean it out some? Could that have anything to do with it? Or is it the rear O2 sensor, and I need a simalator for it? Any help would be great.
Old Apr 3, 2003 | 06:56 AM
hotrodgirl's Avatar
It's probably the 02 sensors. You can check with Auto Zone first, they can put your car on a computer and check it for free. If that's the problem, put o2 simulators on, and the problem will be fixed!
Old Apr 3, 2003 | 06:58 PM
BISHOP's Avatar
See if you can pull the code. It is common with SLP LT's too get a infrequent switching code for the front O2's. This is caused by the front O2's being farther back then the stock location.
Old Apr 3, 2003 | 07:18 PM
stik6shift98's Avatar
definetly an o2 problem......
Old Apr 3, 2003 | 07:19 PM
hrtbeat2's Avatar
code
I went to Autozone and the codes said heater bank O2 sensor 1 and second code said heater bank O2 sensor bank 2. The code started with a P?
Old Apr 3, 2003 | 07:48 PM
those are 02 codes...for sure
if i rember correctly that means they are both on the drivers side....
but i know its the o2s...
Old Apr 4, 2003 | 01:14 AM
AL SS590 M6's Avatar
Moderator
Re: code
That probably means that you burnt the wires going to the sensors. I'd check the routing and the wires.
Old Apr 4, 2003 | 02:32 PM
Camaro ChriSS's Avatar
Re: code
Sounds like the front sensor on each side.
Btw, I think all the codes start with a P.
Old Apr 4, 2003 | 03:25 PM
Re: Re: code
yes all start with p
u can get more info at autotap.com
Old Apr 5, 2003 | 06:54 AM
BISHOP's Avatar
Like I said infrequent switching. O2 simms will not help you. The only thing that works is to reset the computer every time the light comes on with autotap or pulling the connector off the battery and resetting the PCM.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
QuickSilver02
Apr 7, 2015 11:12 AM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
