View Full Version : Forced Induction
- FAST/DFI vs LT1 edit
- remote mount turbo
- vented optispark
- ATI PCV modification???
- Switching pistons
- 60-1 with a t3 .84 turbine housing on a 355, a few ???
- My blown 396 sucks... longish search for ideas.
- People making 550rwhp or more...
- Non Fbody related
- STS Turbo
- Bingo - 3 11.8xx runs
- A few comparison questions
- Better Supercharger?
- Strim runnint 6-8#s, fuel requirements
- Where to order Brad Brand intake?
- what cams
- Thinking about a turbo....
- pte53 on a 355???
- ATI P-1SC Questions?
- Which MSD Ignition For Boost?
- INtercooler piping.
- Turbo+355? or 383?
- Supercharger FAQ?
- Crazy Turbo LS1 dyno #'s
- T trim ?
- Giving cogs another chance...
- YSi-trim really for the street????
- Help with tensioner on P600b!
- Is this true? Mods to fit an F1 in 4th gen?
- Forged 383 kits and cam?
- Turbo headers i have an idea
- Some rare pics of my car
- Vortech 8-rib Pullies
- 355 or 383
- ATI Super dampner. where to buy.
- Dyno'd the Impala- graph inside... need input
- relocating the ASR
- H vs. X pipe w/ Forced Induction
- Fuel Requirement for 12psi Pro Charger
- 450rwhp - 500 rwhp?
- Turbo Sump?
- spark plugs
- Wear and Tear with supercharged Engines
- Ideal head characteristics for each type of forced induction?
- Turbocharged small block with a Carb....
- sound different under boost?
- one good dyno clip
- Requirements for supercharger
- Think this twin turbo kit would fit an LT1?
- Questions on Vortech Supercharger From Summit
- Something wrong
- rear mounted turbo
- Single Turbo LT1 - suggestions...?
- Turbo charging a LT1 camaro
- Turbo Help
- Can I Run A Supercharger With A Hot Cam???
- Automatics, Driveline & Boost
- article mentions possible magnacharger for fbody?
- sts update on the 93
- GT45 Masterpower turbo.. WOW this thing is HUGE..
- ATI belt tensioner.....
- Vortech pully question
- crankcase vacuum through exhaust pipes??
- Timing and boost
- Eaton car dyno
- Procharger install almost done....
- 383 internals question for T76GTS turbo build
- Can i swap a LT1 P1SC procharger to a mustang 94-95??
- MAP sensors
- My 4inch vortech cold air intake
- Using Procharger P1SC with ATI Super Damper?????
- Using a P1SC kit with a ATI Super Damper?????
- found the limit of the stock shortblock
- only 7-8#?? Please help me trouble shoot
- Wow. ATP Turbo really sucks!
- Where to buy intercooler piping?
- ati doesn't fit? i hope someone knows about this
- Need Advice
- Here ... Mounted Vortech Mondo Pic
- COG pulleys & 42.5LB injectors for SALE!
- installing p600b
- ATI F1 guys step in......
- Intercoolers
- PLease help.... INFO ON BLOWNSILVERZ
- What can I expect from procharger?
- oil out of the dipstick after race?
- ati P-1sc how many # wil it go
- first time to the track with my s/c.
- ATI twin intercoolers for LT1
- Traction control removal...
- WTB Aftercooler kit
- once i install my vortech?
- Vortech question
- Turbo tubing
- need help on misfire issues
- anyone have any 75lb injectors for sale?
- Is a pooping noise in the exhaust normal on s/c cars?
- mass air sensor on intake side?
- when tuning an LT1 w/ twin turbos..................
- Cooling an Intercooler
- What Turbo Systems Are Out There For My ls1?
- YS-trim guys please chime in...
- cam question
- High impedance injectors
- What size injectors do I need?
- My supercharging dilemmas....
- anyone using the 2.55 pulley for an ati p600b?
- Single turbo guys, what are you doing for O2s?
- please post any fbody turbo pics.
- single turbo questions
- supercharger
- Help me build an engine that will last
- how much horse with twin turbo?
- 3 core ati style intercooler for sale new for $499.00 on ebay?
- 18ga turbo headers, will they hold up if ceramic coated?
- ATI D1sc inlet hose
- turbo lt1 car on ebay
- please help boost trouble
- hp on a p-1sc
- no start HELP!
- boost question
- d-1sc
- bypass valve?
- Procharger
- electric turbo blower????
- Vortech owner check this lid out!
- p600b or p1-sc
- Looking for information on 17# cog pulleys for a P600B(anyone remember these)
- purpose of using multiple ByPass valves
- electric supercharger?!
- Vortech aftercooler clearance problems on stock Z28 hood
- FS: 94 Procharged Z28
- Turbo Guys: what exhaust gaskets do you run?
- Vortech pulley install question
- Vortech decals/stickers
- laying out my fuel system... review and advise please!
- Car looses power @5000 RPM at WOT only.
- BOV on a MAF car?
- Opinions on this intercooler.
- Install Qs - Vortech icebox
- Whats my blower suposed to "feel" like?? please read s/c guys
- turbos,blower
- loosing boost
- anybody use N20 with Supercharger on stock short block?
- Best prices on turbos....
- 38mm wastegates, big enough?
- Ran the Bluez - Mixed results
- all you turbo guys out there, are your exhuaust systems loud?
- where do you put the Mondo by-pass valve for a Vortech ???
- paging rskrause heh
- bad torque convertor?
- Looking for stroker kit and blower and all of the info and help that I can get
- Where to get Brad brand vortech intake?
- New or Used 8 rib Procharger pulleys????
- What intake pipe for YS-trim
- What compression to go with?
- mass airflow massager?
- help with 383 setup!!
- Newbie to forced induction looking for info
- WTB stock type S-Trim intercooler setup
- Want to Boost. Ways to Lower Compression?
- any1 tried the sts turbo kit?
- 60, 65, 70lb High Z injectors, where to buy?
- Pulley Sizes for a YSi-trim
- New numbers D1SC cogged
- Turbo-vs-Supercharger
- What should I do?
- 3 bar map
- Delteq ignition?
- what kind of transmission is better for turbo charged
- spark plugs
- Where to buy Head units the cheapest?
- Big EGT question
- Which mains caps?
- check this out
- What do you FI guys run for ring gap?
- Seat of the pants difference between turbo & supercharger?
- Blow Off Valve ?s
- First time blower tuning
- 60-1 or t72?
- Turbo that connects and sits at the muffler?
- How Much PSI Intercooled
- Initial twin turbo dyno results
- Is a hot cam ok for a supercharged car?
- Carbuerated Small Block Chevy part's Info
- XX-trim Project
- anyone running a p600b
- advice
- a pic of my twin turbo setup
- Optispark question
- Darn MSD
- How to make a 4L60E live....
- New D1sc installed, but engine won't turn over?
- How to inspect used S-Trim before purchasing?
- What other blowers fit the S-Trim brackets?
- ISSUES w/prochager install
- Weldon products ???
- Can someone please tell me how these turbos would run on my engine?
- twin turbo kits ?
- traction ctrl removal
- Brand NIB IC forsale
- Is a 4" exhaust necessary...
- Best place to tap oil pan for S-Trim ???
- O2 accuracy with aggressive cam timing
- what size pulley and where to purchase for ati p600b
- oil pump and oil cooler questions
- fuel injector size
- Safest Boost Retard
- LT1 I.F.M.S. ? What are the options guys?
- Peak S-Trim V1 numbers
- Considering on Superchagering
- crankcase vacuum pump necessary?
- LS1 Guys with upgraded internals
- What do you think of my Lloyd Elliot heads?
- 1000+ HP and TQ ?
- blowers + spray, fuel pressure?
- Hot cam with supercharger???
- Silicon reducers for relocated Maf?
- anyone have a roots blower??
- oil leak caused by blower???
- Mass Air Flow readings ?
- inlet pics to your S/C please
- 4340 crank, wtb best deal?
- Is a YS-trim streetable?
- boost,knock,and fuel pressure?
- What A/R and what are the characteristics on your combo?
- Interesting twin turbo LT1 setup
- Very basic wastegate question
- what blower makes the most
- Those with Eagle Forged H-beams inside!
- How long would the header to turbo piping be for it to be too long? Pic inside
- seeing no boost....
- eliminating FMU with larger injectors. Any negative effects from lower fuel pressure?
- What do you guys think? Should I get my car dyno tuned this summer?
- 2002 V6 Turbo
- Boost Gauge Question
- Is an oil cooler really needed?
- BOV ?'s
- Lots of boost
- Dynamic compression vs Static compression
- Greddy BOV + Vortech Supercharger kit = whoosh sound?
- Heads and cam
- some set up questions for the experts out there....
- what heads are best for supercharged engine?
- Compressor Maps?
- Injector question
- ATI intercooler question
- Advanced??? Blower questions.....
- supercharger
- Emissions Legal Turbo Manifolds
