please help boost trouble
Old May 10, 2004 | 10:01 PM
95TALT1's Avatar
I have a stock 95 lt1 ta with a vortech s-trim. The problem i have is that i do not build boost until 4000 rpm. I dont even build a lb of boost till 4000 then it just hits like a ton of bricks. Vortech is always busy and I have sent emails. CAN ANYBODY HELP
Old May 11, 2004 | 06:54 AM
IDOXLR8's Avatar
HOw much boost are you seeing at WOT? Also how much vaccum are you pulling at idle?
Old May 11, 2004 | 07:22 AM
95TALT1's Avatar
I get around 18 vaccum and around 8 to 10 boost
Old May 11, 2004 | 07:48 AM
Acct 23749's Avatar
maybe a sometimes stuck bypass valve????
Old May 11, 2004 | 12:21 PM
97RedT/AWS-6's Avatar
Maybe a bad boost gauge? I see between 12 and 14 Hg at cruise/idle, immediately jumps to zero at any rpm below 3000 at WOT, then from 3000 - 6000 builds boost between 1# and 6#, and hits like a ton of bricks at 3500 rpms. I thought I'd see more boost down low too...
RUENUF
Mar 13, 2016 03:37 PM
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Aug 7, 2015 01:26 PM
Henson071
Aug 4, 2015 09:32 AM
