ATI PCV modification???
Old May 31, 2004 | 09:09 PM
BLUE95ZZ's Avatar
I don't understand what ATI wants me to do with the pcv. Can anyone explain this to me a little better. I understand that they want you to move it because of the change from vac to positive. They don't show any pics of this and word it pretty bad. any help would be great.
Thanks Matt
Old May 31, 2004 | 09:49 PM
dnz28's Avatar
basicly you need a valve cover breather or else when you go to start it you dip sticks going to become a projectile, happen numerous times to friends, but if you have the money buy a crank case evacuator, it will even free up a couple hp.
Old May 31, 2004 | 09:52 PM
BLUE95ZZ's Avatar
Thanks but what do i do with the rest of the pcv Ati wants me to reroute the hoses on both sides one from the valve cover the other from the PCV on the driver side of the intake manifold?
Matt
Old May 31, 2004 | 09:59 PM
CJ's Avatar
CJ
All you have to do is on the passenger side remove the hose going from the TB to the valve cover. Cap of the barb on the TB, put a filter on the valve cover.
You dont need to mess with the PCV on the drivers side at all.
Old May 31, 2004 | 10:30 PM
BLUE95ZZ's Avatar
Why does ATI want me to do all that stuff for?
Thanks again ill prob do what you said Thats how my friend did his
Matt
Old Jun 30, 2004 | 10:02 AM
BAD 97 WS-6's Avatar
I called ATI yesterday. I kept my driverside PCV system stock, but they told me if i do that, I will pressurize the intake and blow my seals. I think I am just gonna do what they say. They built it, they should know the best way it works.
Old Jun 30, 2004 | 08:39 PM
Lonnie Pavtis's Avatar
A PCV valve is a 1 way check valve so it should stop reverse flow. I now leave them connected on my installs with no problems as this allows the crankcase system to function as originally intended & should shut under boost.
If you have a bad PCV or excessive blowby you can still pressurize the crankcase.
Old Jun 30, 2004 | 10:00 PM
Live for TAs's Avatar
PCV- oil separator
Check out this link from the Project Trans Am page. It shows how to build an oil separator. I'm going to try this setup on my car.
Old Jun 30, 2004 | 11:00 PM
The reason i was concerned about the stock pcv set up is because i bought a brand new pcv valve and blew in it before installing it. yeah it closed, but now way does it seal. if i was able to get a lot of air to pass thru there with my mouth, imagine a blower.
Old Jun 30, 2004 | 11:21 PM
97TA-WS6-Con's Avatar
I did not like the idea of the PCV valve venting in front of the blower. I found a disrurbing amount of engine oil just in front of the MAF. I ran with a breather only for a while.
This caused me to leak at the rear main seal.
For the build under way now I have bought an electric vacuum pump, oil seperator cap and puke tank. Of course installing it remains an unanswered question.
Search under "vacuum ppumps" for some lengthy discussion on this topic
Old Jul 3, 2004 | 02:56 AM
Tony89GTA's Avatar
You could do what I'll be doing and installing this PCV shutoff valve in the line, should stop boost from getting through. websight here http://www.bowlinggreencustoms.com/s...tomer/home.php
Old Jul 3, 2004 | 03:26 PM
slimdawson's Avatar
I want to keep a vacuum in the crankcase so the oil separator link looks like a good idea.
But, can you build too much vacuum in the crankcase?
Old Jul 16, 2004 | 02:19 PM
TenaciousDB's Avatar
If you have too much crankcase vacuum you can actually risk sucking air an particles in through the rear main seal or through the timing cover gasket. Or worse, you could suck a gasket completely which will require more work that you bargained for.
Bottom line (after reading various threads) seems to be that while you don't want to allow any boost into the crankcase or lifter valley, you're probably fine with just a vent filter on the valve cover(s).
You can probably leave the PCV setup on the driver's side of the intake alone--but make sure you have a good PCV valve so you're not getting boost into the lifter valley.
Dave
Old Jul 16, 2004 | 10:47 PM
BLUE95ZZ's Avatar
I haven't touched my car in a month after installing my procharger within three days i developed a lot of cc pressure. I vented the ds valve cover with a breather and left the pvc alone I can't imagine that in three days i lost a piston. this thing pukes serious oil now. any ideas?
Matt
football4life
Oct 4, 2015 07:48 AM
drt
Sep 27, 2015 04:39 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
