Pulley Sizes for a YSi-trim
Hey guys,
I have just placed my order for a new YSi-trim and I was wondering which pulleys should i order for around 12psi boost and 700rwhp.
I was thinking on buying 10-ribbed 7.4 crank pulley from ASP, but I dont know at what RPM impeller the ysi will make the power im interested in.... I shouldn't be even close to maxing this thing out. so...
Let me know what you guys think..
Originally posted by The Highlander
That was for the 800rwhp mark?
I believe that is too much spin FWIW
Let me know and THANKS!!!
The blower is designed to be run hard. If 700 rwhp is your mark I am sure you could have gone with a smaller head unit.
I strongly recommend that you use a cog setup.
AY AY AY... im glad i bought it.. if I ever wish (which I HOPE NOT) to go over.. it means i can use that same setup... Heads will/should flow over 300cfms so... The YSi seems like a good choice...
Anyways.. I think I'll go with the 7.4" crank and 3" pulley maybe.
Question:
What are you using for tensioner and bracket?
Question:
Question:
Question:
sleeperZ96BT
Sep 9, 2015 08:28 AM
RX Speed Works
Aug 20, 2015 03:40 PM
colts0455
13
Aug 7, 2015 09:15 PM
