355 or 383
Old May 25, 2004 | 10:51 PM
BLUE95ZZ's Avatar
355 or 383
Hey im wondering what is the recomended choice here. When building a blower motor wich would be a better choice a 355 or a stroker? power wise and as far as reliability.
Matt
Old May 27, 2004 | 11:59 PM
OBE1 95Z28's Avatar
I suggest you do a search on this board for answers. Both displacements work well. If you're plan to run modest power, than the stock crank can be used and you'll end up with a 355. If you're upgrading to a forged crank, then it doesn't cost much more (clearancing the block) to step up to a 383.
Old May 29, 2004 | 12:03 AM
BLUE95ZZ's Avatar
Thanks im just trying to see what the best route to go when my stock long block goes south.
Matt
Old May 29, 2004 | 01:09 AM
97WS6SCharged's Avatar
Find a spare block now and start building it. I'd personally go with a 383 since the only real additional cost is clearancing the block for the longer stroke/rods.
Old May 29, 2004 | 03:26 AM
CJ's Avatar
CJ
I went with a 350 on my next buildup, but the only reason was because it was easier to get my desired compression ratio with my current heads and a 350 vs a 383. Other than that, theres no reason not to go 383.
Old May 29, 2004 | 03:48 PM
engineermike's Avatar
The added low-end of a 383 works well with a centrifugal supercharger, which builds boost with rpm.
Mike
Old May 31, 2004 | 10:32 PM
BLUE95ZZ's Avatar
thanks guys im just trying to get some opinions very apriciated
Matt
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
smoknta
Aug 27, 2015 05:07 PM
alphaauto
Jul 26, 2015 04:40 PM
