What should I do?
What should I do?
I found an LT1 Vette block for $350, but would require for me to pay shipping to get it here... Its a 4 bolt main cap block.
I also have an LT1 block thats a 2 bolt main, and have some PG main caps here.
I want the block to be able to handle 800 rwhp or so
Should I spend the extra money to have the 2 bolt block converted or go with the LT1 4 bolt block? It costs $350 for labor and the caps were $100.
Have splayed main caps installed on the LT1 block. It will be stronger than the LT4 block. The LT4 block will handle alot but just only $450 you won't have to worry if you've done the right thing
800rwhp is alot of power, you don't want to take any shortcuts with the block
I agree. The splayed should hold more. You'll want to go forged on everything else, as well... 350 labor for the splayed caps seems a little high if your having the rest of the block machined at the same time.
