38mm wastegates, big enough?
Old May 6, 2004 | 02:13 AM
LT1RX7's Avatar
I'm still thinking if I should install these 2 38mm Tial wastegates I have. Some people have told me they will work but I'm running on the edge of what they can control. I only want to run 6psi for now so I know the wg should be an important part of my setup. You guys think 2 38mm will be ok? Oh, I'm running twin TO4B's. Just don't want to start welding again and have to end up cutting it off. Oh, sorry in advance for all the post I will have up. Starting to get my car up and running into some stuff
Old May 6, 2004 | 02:22 AM
97WS6SCharged's Avatar
I think you'll be ok with the 38's myself, but if you're still uncertain, give Precision a call and see what they recommend.
1-219-996-7832
Old May 6, 2004 | 08:22 AM
JZ 97 SS 1500's Avatar
The Tial's will be fine. The 38mm will bleed a good bit of boost.
Jose
Old May 6, 2004 | 09:34 AM
mongse_1's Avatar
I'm running twin 38s on mine and I've got slightly larger turbos than you.
Old May 6, 2004 | 01:28 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
i think 38s are good for your app
keep us updated on pics :-D
Old May 6, 2004 | 08:44 PM
Not to steal your thread or anything, but Jordon, what size wastegate were you using on your car when you had the 88 on it?
Old May 7, 2004 | 10:25 PM
SMOKNZ's Avatar
I'm using twin Tial 38's on mine as well.
Bill
Sep 18, 2015 03:46 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
96SilverRam
Aug 9, 2015 04:15 PM
NewsBot
Aug 3, 2015 02:40 PM
Louey
Pacific
Jul 27, 2015 09:58 PM
