Ideal head characteristics for each type of forced induction?
Old May 24, 2004 | 11:28 AM
LameRandomName's Avatar
I'm not hugely knowledgeable about forced induction, but I do know that turbocharging and supercharging have different behaviors/characteristics from each other and from natural aspiration.
The main difference, at least for the purposes of the question I am about to ask, is that supercharging has no real effect on the exhaust side, other than producing a much higher volume of exhaust, while a turbocharger "interferes" with the exhaust to make it's power, requiring, among other things; a different camshaft design. If you want the best efficiency that is.
In terms of the following head characteristics:
> Chamber size
> Valve size
> exhaust flow as a percentage of intake flow
What would be the most efficient head designs for turbocharging and for supercharging?
I know the design considerations would be different for each, but different HOW?
Old May 24, 2004 | 01:53 PM
stealth2's Avatar
The answers to these questions are complex and extensive and would be better determined through your own analysis and investigations.
Old May 24, 2004 | 02:00 PM
Gosh, that was helpful.
Old May 25, 2004 | 09:44 PM
engineermike's Avatar
My $0.02:
Cylinder head flow is much more important on a supercharged head than naturally aspirated.
We'll look at the intake and exhaust strokes separately:
INTAKE: The single largest restriction in the entire intake system is around the intake valve. So, with a supercharger, you're trying to push twice as much air through the same port and valve. This means that the port is twice as restrictive to flow. So, a supercharged engine needs a much better intake port than NA. I know this goes against most accepted logic, but think about it. . . A good NA engine might get 110% VE. A good supercharged engine might get 160% VE at 14 psi boost. Why isn't it 220% VE since you doubled the density of the intake air? Because it can't actually get into the cylinder.
EXHAUST: A low compression supercharged engine retains cylinder pressure much later than a NA engine during the power stroke. Therefore, we must delay exhaust valve opening (EVO) as compared to NA engines. Again, this goes against common logic. But. . . you can pair a delayed EVO with an exceptional exhaust port and achieve more power throughout the curve. Of course, a good exhaust port will help any S/C motor, but the properly matched cam can produce better even better results.
Mike
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
87Aerocoupe
Mar 20, 2015 01:23 AM
