What compression to go with?
Old May 3, 2004 | 03:47 PM
30thCamaroZ's Avatar
Building a 383 for boost. Going to use the new Trick Flow heads with the CC306 and not sure who's turbo setup yet but will prolly use a T76 with whoevers I go with. May have a turbo setup made locally. Anyways. Just wondering what sort of compression I should go with. I will be using JE pistons, H beams and a 4340 crank. Also what is the stock CC on the combustion chambers of the LT1 heads? Thanks
Old May 4, 2004 | 06:12 AM
IDOXLR8's Avatar
For a turbo setup I would highly recommend going with 8.5:1 compression. Since I assume you want to most out of your setup I would highly recommend swapping your CC306 cam for a custom turbo cam.
Old May 4, 2004 | 08:05 AM
stealth2's Avatar
Depending on where you live and race, I agree that 8.5:1 sounds right.
Old May 4, 2004 | 08:16 AM
rskrause's Avatar
Moderator
8.5:1 sounds about right for low to moderate boost. If you plan mega-boost, I prefer even lower. Definitely no more than 8.5:1, especailly considering that turbos usually use small cams.
BTW: CC306 is a crappy choice for a turbo.
Rich Krause
Old May 4, 2004 | 09:13 AM
JZ 97 SS 1500's Avatar
Go 8.3-8.5 CR, and ditch the CC306 like Rich said. You will bleed all your boost away with that cam. The 76 is a great turbo and you will like it very much. As far as the stock CC for LT1 heads its 58CC.
Jose
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
pimpss96
Feb 12, 2015 01:28 PM
