Which MSD Ignition For Boost?
Old May 29, 2004 | 02:36 AM
Rich_z28's Avatar
I've got a stock motor that I'm getting ready to add an ATI P600b intercooled S/C to and need an MSD. I already have a blaster coil. Just looking for the ignition system itself? Thanks in advance.
Old May 29, 2004 | 03:57 AM
97WS6SCharged's Avatar
http://store.summitracing.com/partde...art=MSD%2D6462
http://store.summitracing.com/partde...art=MSD%2D8877
Old May 29, 2004 | 09:05 AM
rskrause's Avatar
Moderator
I am using the 6AL, which seems to work fine.
Rich
Old May 29, 2004 | 06:09 PM
OBE1 95Z28's Avatar
The best way to supercharge is to have the computer reprogrammed while the car is on a dyno. Next best is a mail order program, verified on a local dyno. If you're going to run a stock motor and just bolt on the blower, you'll need a ignition system that you can manually take out timing under boost. You'll need the boost timing retard module that MSD sells; Crane also makes an ignition with a boost retard module.
Old May 29, 2004 | 11:16 PM
ATMINF's Avatar
I have had problems with the MSD BTM setup that has both the 6AL and BTM built in one box. Mine went out twice, I then got a 6AL and BTM in two seperate setups(hope that makes sence), and have not had a problem in about four years. So my recommendation is run a sperate MSD6AL and MSD BTM and you should be good. It also costs about $500-550 if I remember right. Good Luck
Old May 29, 2004 | 11:44 PM
rskrause's Avatar
Moderator
The linear relationship between retard and boost provided by the BTM or equivalent boxes from other manufacturers is a terrible way to adjust timing for boost. The ideal setup in that regard is an aftermarket ECU which can use a 2 or 3-bar MAP sensor. There are other issues with an aftermarket system though, and it certainly isn't needed for a stock motor with a blower. The best all-around solution for that kind of a setup is PCM tuning. An aftermarket CD ignition box is still a good idea because you need a stronger spark with boost. However, with a max of 6psi on a stock motor (more is a very bad idea) you could probably just use the stock ignition along with non-platinum plugs.
Rich Krause
Old May 30, 2004 | 01:47 AM
Rich_z28's Avatar
Where can I find a 6lb. 8 rib pulley? 6lbs. is all the boost I wanted to run also. Thanks guys.
Old May 30, 2004 | 08:56 PM
95 Silver TA's Avatar
I have a MSD 6A that I am not using anymore since I got my Delteq system. If you are interested, its for sale. I want 85 Shipped for it and it works great.
Thx,
Claude
Old Jun 1, 2004 | 06:25 AM
IDOXLR8's Avatar
You can call ATI or ASP.
Old Jun 1, 2004 | 07:22 AM
MSD 6A, Stock Coil, & Ign Module For Sale:
All works great...I am selling because I upgraded to the Delteq system.
Ignition Module: 45 Shipped
Stock GM Coil: 17 Shipped
MSD 6A box: 85 Shipped.
Or buy all for 140 Shipped and save 7 bucks.
Thx,
Claude
96SilverRam
Sep 7, 2015 10:51 PM
dkred94z
Aug 20, 2015 03:09 PM
Henson071
Aug 4, 2015 09:32 AM
88IROC_Z
Jul 22, 2015 11:38 PM
