pte53 on a 355???
Old May 29, 2004 | 02:08 PM
sleepybu's Avatar
Smile pte53 on a 355???
They clame it'll support up to 610 hp at the flywheel which is good enough for me . If i want more later i'll add another one.
I was thinking of getting it with the .81 A/R T4 tangential turbine housing to help reduce lag. I have auto trans and don't want to put in a big stall cuz it's my daily driver. Then motor is a flat top 355 with stock 76cc heads with some porting(about 8 to 1), cam is a hydro flat tap 226 @ .050 .480 lift 114ls. This will be a carb set up for now. I'm planing on using the stock exhaust manifolds since i'm not looking for big power and it'll save me alot of fab time. I was also looking at using the hks 40mm standard wastegate.
comments please
thanks
http://www.precisionte.com/products/...=Turbochargers
http://www.precisionte.com/products/...ard+Wastegate:)
LeftoverChinese
Jan 14, 2024 03:03 PM
Z Power
Sep 19, 2015 11:19 PM
whitehooptie
Aug 17, 2015 08:35 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
InfernalVortex
Jan 17, 2015 09:35 AM
