ati P-1sc how many # wil it go
Boost is all relative to engine size & flow capability.
about 15# on a stock LT1 350
about 10# on a good flowing 383
This can easily vary by 3# in either direction depending on specific cam, head & exhaust choices.
http://www.procharger.com/models.shtml
Procharger rates it for 30 #... I'm just guessing here, but I figure the rating has to do with being too much load on the bearings if it has much more load on it.
Yeah, sure you could get 28 PSI with a P1 on a Honda Civic, but it just isn't capable of flowing enough air to make that much boost on a good flowing 383.
I am sure it wouldn't be the best blower at 30psi, but there's got to be some sort of specs on how they grade them. I wouldn't think there'd be THAT much of a CFM difference between a Honda and stock LT1 that 28psi on a Honda is better than it would be on an LT1. I also have a hard time believing the P1 is only good to 15psi.
No, I don't think you're getting it... The supercharger can only put out a certain amount of air at max RPM. So if you are spinning a P1 at it's max 62k RPM it's going to be flowing 1200 CFM. No matter what motor it's attatched to, thats all you will get out of it.
Boost is a measurement of restriction.
for example, Say a NA 1.6l honda flows 200cfm WOT... force 1200 CFM into it... that's 1000 extra cfm trying to fit into 1.6L, you may see 30 psi
where as a 383 NA LT1 flowing 600cfm, well if the same blower is flowing 1200 CFM, that's an extra 600cfm, going into 6 liters, you can see how it will definetly be lower PSI, as there is less restricion... 10-15# or so.
So when it's rated for 30 psi, that doesn't mean you'll be able to see that much on any motor you put it on. I made up the numbers in the example, but you get my point?
I'm assuming when they rate it for 30psi, that's how much pressure the impeller/bearings can withstand for an extended amount of time.
To actually see 30PSI on the 383 you'd need something like an F-1R at 2000 CFM.
Good luck on those blower seals.
Here is a ballpark approach to airflow.......
Note it does not take into account: induction flow capabilities or volume changes due to charge heating (air expansion).
Take a P-1SC at 1200cfm.
A 100% efficient 350ci motor flows 607cfm at 6000rpm.
14.7psi is roughly 1 atmosphere of pressure.
((1200cfm/607cfm)*14.7)- 14.7 equals 14.36# boost.
This is based on max charger output at 6000 engine rpm & 100% efficiency (intercooler/aftercooler) temp.
Once you heat the air, boost also goes up.... the less that the intercooler cools the mixture the more boost you will see.
Do the same with a 350 running at 3000rpm & the supercharger maxed out & boost will double. The same with an engine 1/2 the size at the same rpm.
This is a crude approximation at best, but gives you some idea of the pressure relationship.
The boost capability of a charger is related to the compressor pressure rating. For example a rating of 2 (which is in atmospheres) 2 X 14.7 = 29.4# boost.
Hope this helps.
Hope this helps.
SpeedJunkee
Jun 6, 2015 04:27 PM
stockssn2o
May 25, 2015 08:54 AM
Red_94Formula
Mar 7, 2015 09:21 AM
