My 4inch vortech cold air intake
http://jon.shoberg.net/CarStuff/Pics/coldair
I'm going to have one of the welds redone to give a bit more clearance but the above pictures will provide an idea. Its a 4inch elbow which will connect to 4inch ribbed-flex hose and then to the large K&N cone filter.
Solid 4inch is pretty rigid and a tight fit under the nose of the car also. Going with the ribbed powerflex hose allows a bit of adjustment. Plus the ribs are solid enough that they won't collapse under boost. The t-trim inlet is 3.75inches so this should be a bit of overkill.
Hopefully it will pull some air ...
Updated with a few more pics and the powerflex hose ... all 4 inch and ribbed to not collapse.
http://jon.shoberg.net/CarStuff/Pics/coldair/view
94z28jbw
Sep 8, 2002 03:22 PM
ezcheeze15
Aug 26, 2002 01:28 PM
slothgrant
Aug 22, 2002 03:01 PM
