laying out my fuel system... review and advise please!
Old May 7, 2004 | 09:39 PM
NC-LT1's Avatar
ok, I am in the process of putting together my list for the fuel system.. here is what i have so far..
twin intank walbro GSS340's.. running up two -8AN lines through the fuel sending unit/filler neck bracket using -8AN bulk head fittings , and then two 90 degree fittings and hose running into an Aeromotive Y block... below, if the image comes up:
then leaving the Y will be a -10 AN fitting up to the engine compartment with a -10 compatible filter inline, and then going to my new aeromotive AFPR seen below:
then the stock single -6 return line to the tank. the fuel rails will be modified to accept the larger fittings to close the fuel system. I have been told this may be overkill for what i am shooting for, but if overkill does not hurt performance at the lower level, then i will be fine with it so i can grow power wise without having to go back through the fuel system except perhaps to add a fuel pump management box or go with upgraded custom fueol rails for flexibility. please advise on this setup!
thanks,
Chris
Old May 8, 2004 | 02:27 PM
BruceVette's Avatar
I am running a twin 255lph in side the fuel tank and a twin -06AN feed line thru a Russell fuel filter and to a Y than to Aeromotive external regulator than another Y to the rail. I feed both -06AN to the rails. This fuel system should be good for my 1000hp goal. Soon I will have my car dyno to confirm my hp.
DirtyDaveW
Dec 1, 2016 05:37 PM
chuyz28
Jan 27, 2015 08:53 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
ChrisFrez
Dec 28, 2014 02:25 PM
NewsBot
Nov 25, 2014 11:20 AM
