Forged 383 kits and cam?
Old May 27, 2004 | 07:48 AM
RealQuick's Avatar
I am thinking of building a 383 forged stroker motor. I cant spend more than 3500 total (that includes machine work). I am thinking about running 12-15psi (maxxing out my vortech S trim). I also need to get a blower cam that will pass emissions. If any of you can post a link to some stroker kits (I already checked the sponsors and found that racenet and CM have good pricing on parts) and also a cam recommendation for this blower. I know everyone says get the 224/236, but will it pass emissions? Any help would be appreciated.
I did a search, but it didnt really help me.
Old May 27, 2004 | 11:39 AM
RealQuick's Avatar
Maybe a custom ground cam would be better for me? Any recommendations on duration, lift and lsa?
My goal is to be around 550-600rwhp with as much boost as my little s trim will produce
Old May 28, 2004 | 07:32 AM
RealQuick's Avatar
Well, I think I might go with this kit. Seems like all the components are forged right? Will it handle 12-15psi and power outputs upwards of 600rwhp?
EG-37557-31 - Eagle 383 cubic inch Low-Compression (blower/turbo) Rotating Assembly
4.030" Bore SRP -31cc dish pistons, 3.75" stroke Eagle forged crank, Eagle forged 5.70" H-Beam Rods ($1749.97)
Also, what blower cam will pass emissions in a 383? I am thinking that maybe the 224/236 114lsa might not, so maybe a custom ground cam like a 220/232 114-116lsa may be more reasonable? Any suggestions?
Old May 28, 2004 | 07:36 AM
rskrause's Avatar
Moderator
CC XE lobes #3190/3192 on a 114LSA will pass emissions and is a great street blower cam.
Rich Krause
Old May 28, 2004 | 07:49 AM
RealQuick's Avatar
Rich Krause
Is that the 224/236? High lift or low lift?
Old May 28, 2004 | 08:08 AM
RealQuick's Avatar
It looks like the 3190/3192 is the following:
214/224 .565/.605 (1.6RR's). Is that too small for a 383? What kind of power levels with that cam support?
Old May 28, 2004 | 09:01 AM
rskrause's Avatar
Moderator
Mine made 613rwhp with an S-trim through cats and mediocre heads (AFR 195 out of the box with no porting). That was with 1.5 rockers.
Rich
Old May 28, 2004 | 09:02 AM
RealQuick's Avatar
The 218/230 .528"/.555" looks good, but the lift is low. Can I have any lift custom ground, or is whats on that catalog is all there is too choose from?
Old May 28, 2004 | 09:09 AM
RealQuick's Avatar
Rich
Stock ecu?? Any tricks to get that power? What boost level? Does the kit i mentioned form CM seem like it would do the job? I plan on making it a 4 bolt main as well. Thanks for the input.
Old May 28, 2004 | 12:19 PM
RealQuick's Avatar
I have been doing alot of reading on the searches, and i had a question. Is there a version of the 224/236 that would pass emissions (114lsa, 115lsa, 116lsa)?
LeftoverChinese
Jan 14, 2024 03:03 PM
transam_388
Mar 15, 2015 11:53 AM
Queens94z28
Nov 20, 2014 06:03 PM
97 RedSS
Jun 10, 2003 07:58 PM
