Tires??
Old Nov 18, 2002 | 09:54 PM
RobertoZ28's Avatar
Question Tires??
What are the largest size tires I can get for my rims?
I have the standard 16" 5 spoke rims that come on the '98 Z28s.
I have currently 245/45's on them now. How big can I actually go? 275's? 305's??
Anyone know, or has anyone done this???
Thanks in advance.
Old Nov 18, 2002 | 10:08 PM
LS1CAMARO's Avatar
I would not go larger than 255.
Old Nov 20, 2002 | 07:37 PM
RobertoZ28's Avatar
any other opinions? I was hoping I could go bigger...
but if not...oh well.
Old Nov 21, 2002 | 10:35 AM
supersp0rt's Avatar
above a 255 is not recommended nor advised. certainly not a 305 or even a 275...its just not a good idea. just like the old putting 315's on a 9.5'' wheel...not a good idea. just run some nitto's in the 245 size and youll hook up better than any street tire.
Old Nov 24, 2002 | 05:56 PM
RobertoZ28's Avatar
Question Suggestions?
alrighty then.
Other than drag radials, does anyone have good suggestions on what make?? I would like a moderate performance tire but not excessively pricey. $200 or so per tire.
Sorry to sound so helpless, but I haven't bought tires in about 4 years! So I appreciate all the help!
Old Nov 24, 2002 | 08:51 PM
2002Z28SSConv's Avatar
I really like the Kumho Ecsta 712 Supras. I've never owned a set but have heard VERY good things about them. I will be buying those when my F1's wear out.
They come in 2 sizes I would recommend depending on your definition of "How big can I actually go?".
245/45/16 is the widest of the two by about 1/2". $90
245/50/16 is the tallest of the two by about 1". $85
There is also a 255/50/16 that is juat a hair wider and 1/2" taller than each of the above. I'm not sure if you'll have any clearance problems but it should fit okay too depending on what suspension mods you have. $89
http://www.tirerack.com/tires/tires....CSTA+Supra+712
Don't let the price fool you. These are great tires. Just ask around.
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
Daluchman1974
Sep 11, 2015 06:12 AM
scottcba1
Sep 8, 2015 09:52 AM
rideordie
Sep 7, 2015 08:22 AM
Slayer
Jul 4, 2015 03:06 PM
