SLP Grille
Old Nov 9, 2002 | 10:28 PM
zzPop's Avatar
Question SLP Grille
I would like to replace my grille with the SLP bowtie grille. How does the old grill come out? Thanks
Old Nov 9, 2002 | 11:00 PM
mystic98Z's Avatar
grill
i pulled my grill out with pure force(ripped it out)..be careful though..you should pull each side out first before the middle and make sure that you have someone else holding the bumper in place while you pull...but realize that this probably will damage the grill so dont plan on selling it after you take it off..it wont break in half or anything but it might get bent up a little(mine did)...if you dont want to do that then you can take off the bumper and then unscrew the grill out from there then put the bumper back on.. its yer call...anyway the grill looks great when u put it on...u can see it on my car
Old Nov 9, 2002 | 11:20 PM
zzPop's Avatar
OK,I thought the old one would just pop out. Does the new grille just pop back in place or does it need screws to hold it in??
Thanks for the reply.
Old Nov 10, 2002 | 12:23 AM
therealmagyver's Avatar
Cool
I just put a billet grille and it was simple. You can just pull on the stock grille. Have the ends pop out first then the center. On the billet it screwed in. Pretty easy.
Old Nov 10, 2002 | 08:49 AM
02CamaroZ28's Avatar
The SLP grill requires 6-8 holes to be drilled. Then you just use push screws to hold it in, takes alot of force to get those buggers in.
Mark
Old Nov 10, 2002 | 11:52 AM
zzPop's Avatar
thanks, I didn't think it was a major job, just wanted to make sure.
Old Nov 10, 2002 | 12:50 PM
JaysZ's Avatar
I have done 2 billets.
Work from both outside edges towards the middle of the grill. First, the grill snaps in at the left and right side of the grill. Reach in with a dull butter knife or something to pry the grill out of the notches (watch the paint). Now the grill will be popped out from the far left and right. Next, if you remove the 3 pushpins along the bottom of the front fascia (underneath the car, I jacked the car up in the front) you can reach in behind the grill. There are 3 or 4 small clips that can be dislodged if you manipulate them from behind the grill. Pull on the grill at the same time. They should each pop off. These are left and right of center of the grill (2 on each side, I think). When finished with these, there will still be 2 large, 'rivet like' clips remaining on the top and bottom center. I've only been able to tear these last 2 out. Basically, you will be tearing the plastic stud through the 'nut like' retainer on the backside of the grill. Have someone hold the fascia as you tear the grill away. A rocking motion will work the plastic stud through the hole and then it will pop off. Top and bottom are the same.
Done and done! Or you could just tear it all off.
I salvaged the old grill on my second job. On the first job, I ruined the grill during the removal process.
I worked with 2 different billet grills. 1 required 4 screws, the other, 4 rivets. I prefer the screw type. Very easy to put on.
Good Luck!
Old Nov 10, 2002 | 12:57 PM
JaysZ's Avatar
If you want to do it the GM way, here you go:
http://www.hoodscoop.com/ssgrille.pdf
Old Nov 10, 2002 | 07:19 PM
Jason 94Z's Avatar
Wink
Actually, the SLP bowtie grille just attaches w/ double-sided tape. They include the tape w/ the purchase of the grille. At least, that's how mine came. Good luck!
Old Nov 12, 2002 | 08:58 AM
NickFL's Avatar
Pull it!!
...I asked the same question when I replaced my stock grill. I ended up just pulling it. The clips fell behind the bumper, and the black plastic threaded pieces were pulled off. Dont plan on reusing it, or selling it if you do it this way!! The SS grill that I installed needed holes drilled and then black plastic Christmas Tress Plugs. Here is the grill that I used. I had a friend who had an SS he was selling, and he swapped grills with me. We took off the SS badge, and ordered a red bowtie. The total cost for my project was $12.95! That was quite a fortunate situation!
Old Nov 12, 2002 | 07:28 PM
zzPop's Avatar
Re: Pull it!!
Nice picture of the grille, this should have been standard trim on the '98 and up Camaro. The stock one screams CHEAP plastic.
thanks for the info.- Lynn
Old Nov 12, 2002 | 08:07 PM
NickFL's Avatar
Thanks...
...I totally agree. The other grill looks like crap compared to this one. Good luck!
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 12, 2015 01:53 AM
CARiD
Sep 30, 2015 05:44 AM
sahlomonic
Parts Wanted
Sep 22, 2015 03:13 PM
tommalcolm
Sep 11, 2015 03:39 PM
