hot cam in 2002 z28
Old Nov 20, 2002 | 06:40 PM
99huggerorangeZ's Avatar
Question hot cam in 2002 z28
if i install a gm performance parts lt4 hot cam will that affect my computer
also do you know where i can find a 382 lunati stroker kit for the ls1 or any other stroker kit that are reputable and cheap?
Old Nov 20, 2002 | 06:45 PM
6speedZ28's Avatar
LT4 hotcam won't work in an LS1. They do however make an LS1 hotcam and as with any cam change you should have your PCM adjusted accordingly.
Old Nov 20, 2002 | 06:48 PM
35thanniv.SS's Avatar
I would recommend reprogramming your PCM. Your car will run alright but not at optimum performance. It will also smooth out that rough idle from a 112 lsa.
Old Nov 20, 2002 | 09:01 PM
Question
where can i have my computer reprogrammed
Old Nov 21, 2002 | 05:52 AM
JackZ.Twenty8's Avatar
At one of the performance vendors. Get a different cam though man, there are just too many great ones out there these days. Get a program to match.
Old Nov 21, 2002 | 09:01 AM
antta99's Avatar
The LS1 Hotcam is a great cam for the money.I put one in my 99 T/A and it made killer power. You might have to drill your t-body to get it to idle though.With long tubes and off road exhaust my car made 358hp and 353tq at the wheels.
Old Nov 21, 2002 | 01:11 PM
redz_02's Avatar
if you want gm, get the hammer cam, does pretty good for a mild cam
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
ANDYZ28
Dec 29, 2014 09:13 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Burn_Out
Aug 18, 2002 08:49 AM
