Called SLP, got info on speedometer recalibrater
Old Nov 15, 2002 | 07:02 PM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Thumbs up Called SLP, got info on speedometer recalibrater
Gentlemen;
A few days ago I posted an answer to a fellow member about using the SLP speedometer recalibrater, in lieu of the HPP3, and was informed by a few posters here that the unit also adjusted the top speed limiter setting in the PCM.
I called SLP this morning, and spoke to their "Tech" department, and they patched me to a electrical engineer that was familiar with the unit, and his answer was "that the unit is only designed to change the incoming electronic signal to the PCM to correct the speedometer". He also added that the only way to change the TSL setting is to flash the PCM. If you install the unit incorrectley, he stated the unit will not work at all, and in no way can change any other setting other than the speedometer signal.
The purpose of this post IS NOT TO BE RIGHT OR WRONG, it is to correct any mis information that maybe out there concerning the recalibrater.
SteveC
Old Nov 17, 2002 | 09:00 AM
SteveC's Avatar
Smile
ttt
novaiiman
May 15, 2016 11:36 AM
HarleyZ28
Oct 5, 2015 06:23 AM
RickRay
Events and Cruise Spots
Apr 23, 2015 02:50 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
mattstrike
Mar 12, 2015 10:12 PM
