Got some qtr mile times in the 2002, what do yall think
Playing with the gtech today, had everything zeroed out perfect on 4 runs, one was hp, gave me 302 to the rear wheels. then i ran a 14.1 at 108.5 a 14.0 at 108.3 then a 13.7 at 109.7. These runs were with driver (me
) and a passenger, both about 200 lbs. Still having trouble with luanching, but the mph has potential for more. What do yall think.
It's definately off a little bit. But you're at least in the ball park. The best use for the GTech is to compare against a baseline before and after you do a mod. For actual documentable times, go to the track. You'll either run quicker ET or slower MPH when you go to the track. If you only run a 14.0 your speed will probably be just over 100. If you run 109 your ET will be very low 13's.
You have to also consider reaction time. My turbo timer has a 1/4 mile thing in it but it starts the clock when it feels the wheels start to move. Not sure exactly how the G-TECH works but if it's like my turbo timer then you have to add a bit for reaction also.
thanks for the replys, Its my friends gtech and i thought i would try it out. I work on the weekends and and go to school during the weekdays. Sucks b/c we don't realy have a track here in corpus, and my schedule keeps me from running up to houston or SA to get some 1/4 mile times. Just thought i would throw it out there and see what everyone thinks. I was pretty impressed with the mph, even if the gtech is off 2 mph (which they say) then thats still 107 and a pretty good trap speed.
still having traction problems, when i hit second i can feel the tires let loose rather than chrip, mustered up a 13.64 at 111.9. On another run I missed 3rd , best luanch i have done, got a 14.56 at 75. Still managed to beat my friends 5.0 time with the gtech with that 14.5 though
. Maybe i should wait and get some wider tires before i put the 4.10's in.
I have taken a 00 A4 z28 and a 02 A4 z28 and nailed an easy 13.4 with both. Just about any stock ls1 can get 13.5 and under, especially with that 6 spd. Traps are consistently 105-106mph. Just dont get too excited on the tree and end up with 2.2 or worse 60 fts.
i wanna try one
i wanna try a g-tech just for some screwing around....ive never heard of this thing:
the turbo timer or whatever it is, does anyone know who makes it?
also, toykilla i hope you dont think that r/t has anything to do with your ET at the track, cause it doesnt.....not sure if i understand what your saying but thats what it sounds like
gives me a good ballpark though, beats having to buy a helmet and so on. I expect the mph to be 2-3 mph off, or so i was told by the owner of the g-tech. He runs it with his 2001 gt at houston raceway. It is a fun toy none the less
Re: i wanna try one
A turbo timer has no real purpose on an N/A car.
