383 help
Old Aug 27, 2007 | 07:07 PM
zl1dreams's Avatar
383 help
hey guys, i just got my set up running on sunday. the car is runnig well, great idle. seeing as how i am new the v8 world(had an 87 GN) i was just wondering if i could get some general info from all you FI guys.
this is my set up
383 with apx 8.5:1 comp
comp 224/236/114
trick flow 62cc heads
42# injectors
gmp timing chain
accufab AFR
255lph pump
52mm tb
headers w/ypipe and cut-out
msd cap and rotor
csr EWP
1.6rr
ngk tr6
madz28 tune
its set up right now with powerdyne s/c with the 9# pulley but its only giving me 3.5# right now. i knew it would not be 9# but i thought at least 6#. anyways im now looking for a bigger blower.
anyways besides the blower, what else should i know? i read something about the MAF only being good for 500hp? anyways anything that you guys could let me in on would be great.
Old Aug 27, 2007 | 09:24 PM
zl1dreams's Avatar
really guys i want the car to be running good and safe and not have to be second guessing what ive done. im not asking so that i can build something bigger and better than everyone, i just want a fast LT1 camaro.
so any advice would be great
Old Aug 27, 2007 | 10:38 PM
joe-96z1le's Avatar
You should get a custom dyno tune. I also think you'll need bigger injectors, dual fuel pumps or at least a BAP. Your clutch probably won't last long, might consider getting a stronger driveshaft and upgraded rear end. Really depends how much rwhp you're looking for? 500, 600, 700? Decide what blower you want. D1SC, F1A?
Old Aug 27, 2007 | 11:38 PM
That Camaro Guy's Avatar
What do you have for tubes into and out of the blower? Belt tension on those are something else to consider.
-Pete-
Old Aug 28, 2007 | 03:20 PM
zl1dreams's Avatar
ok so the 255lph isnt big enough. my buddy has a set of 50lbs msd injectors i could swap him for.
i just installed a spec 3 clutch which should handle the power.
ive read that the most power you can make from a powerdyne is 11psi on a stock heads and manifolds so its pretty much pointless to put money into it, so im looking for a bigger blower.
once i get everything i need ill get it on a dyno and have it tuned at the same time.
its a street car for now so the rear end will stay untill the next spring seeing as how i cant drive it from december untill april.
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
smoknta
Aug 27, 2015 05:07 PM
alphaauto
Jul 26, 2015 04:40 PM
