Most Popular Radiator for Stand Up use?
C'mon guys, I tried searching but couldnt find any actual part numbers? I am in need of a stock radiator right now (because someone stole mine). I also want to eventually go turbo and i need the extra room.
dude thats a touchy subject lol.... for a stock radiator there really are not any that are thinner or anything. you can how ever do the upright mod w/a different radiator which is better for a turbo build. take a look at the sticky in Forced Inductions there has gotta be a part number in there this pretty much what i came up with for a mounted up radiatot..
http://store.summitracing.com/partde...5&autoview=sku
I was under the assumption that the stock fans were a bigger issue, not so much the actual radiator. If you want to run the stock radiator, just cut the bottom support and make some brackets to make it sit more vertical.
