Best Turbo Piston/ring combo for my setup?
My shortblock is nearing the finishing touches and I need to get the pistons over to the machinist. Given that some go with the Ferrari of pistons(Diamond?) while others go with Kia of pistons(TRW) I want something in the middle of the extremes. I'm going with 14 to 17 psi on my T76 w/MPS Wheel on a 4340 forged crank 355 LT1, using Realquicks Log Manifold for the hotside. The car is going to be a daily driven/weekend track application. The static compression ratio is going to be 8.5, the block zero decked, the heads ported LT1 castings (I/E flows of 275/195), 60# Mototrons, PCMforless turbo tune, TurboSmart 38mm WasteGate, TurboSmart Megasonic Blow off valve, OBX Intercooler. You guys with 'real world' experience in piston selection, could you recommend a piston/ring (and possibly a vendor) that would satisfy the needs of such a motor/application? I'm ready to buy right now. I'm ordering the 5.7" H Beam rods (Rated to 1,000Hp) right now as well.
Thanks!
Dave
Thanks!
Dave
Thanks for the response. I'll look for them. I think when I was fielding some questions regarding inverted dome size, they said it would take around -31 CC's to get 8.5:1 SCR with the ported LT1 castings, zero deck, .03x compressed head gasket. Do you have a vendor you can suggest?
If your machinst can get them at a decent price, that is going to be the most convenient. It will make him happy to make a couple of bucks on the deal. I don't buy many parts retail, but all the big retailers sell JE. When I buy retail I use Flatlander Racing at http://www.flatlanderracing.com/ or Summit. My buddy Bob Kennedy also sells retail, but I don't want to seem to be doing free advertising.
Rich
Rich
I guess you'd assumed (correctly) that I'd scanned the field and found JEG's SRP Super/Turbo pistons (-21cc or -24cc?) for $5x each.
Are your Ross pistons a shelf item or custom? I've put in a 'cam request' to Cam Motions for a custom turbo Cam this past Friday.
another for je a friend of mine has em in his 97 s-10 with a pro charged 502 in it and they hold up real well he scattered a set of wiseco on the same set up i think his are a -24 dish and 8.8-1 on 13-18 lbs of boost
About the cam request. . . I'm not a big fan of Cam Motion. When they call back with the cam spec's, quiz them on why they chose those numbers. They never ask for backpressure, though that should be a key element in choosing a turbo cam. All of their recommendations are reverse split with about 5 deg more on the intake, and all ground on a 114. That CAN'T possibly be right for all the combo's they recommend cams for. . .
Mike
Mike, Here's their quote...
Dear David,
Recently, you submitted an Cam Request named Turbo 355 LT1 using our online Cam Request system at cammotion.com. The request was for a HROL for a Other. We have reviewed your submission and have provided the information below. Thanks very much.
RECOMMENDATION
Grind Number 1533/1533/14+4
Duration (intake/exaust) 228/228
Lift (intake/exaust) 563/563
Lobe Center Separation 114
Intake Centerline 110
Comments 355.00 with Cast Gear Core 300.00 for billet core
Price US$
Please advise if you wish to order
We can ship in as little as three days!
Cam Motion, Inc.
2092 Dallas Drive
Baton Rouge, LA 70806
Dear David,
RECOMMENDATION
Price US$
Cam Motion, Inc.
2092 Dallas Drive
The rings did come with them. As far as I know, all ring manufacturers recommend a generic end-gap. However, we learned some interesting stuff from the guys at JE a couple years ago and I've been going much wider ever since. I think my current motor is .028-.030 on the top and .018-.020 on the 2nd.
Mike
Mike
Sounds pretty generic, though a tad different from their typcial recommendation.
BTW, a few years back, I switched to a 226/226-114. Results were underwhelming, so I put my 224/236-114 cam back in.
Mike
Mike
Well. I called around and checked various sites. The SRP -31 piston was a good deal at $500ish for the set was very attractive but I've found about 3 guys that said they don't trust them after either suffering a failure themselves or knowing a bud that had in a supercharged/turbo motor. I know this *could* be related to setup, ringgap, detonation, fuel system issues, overly aggressive timing, etc but the issue is out there to evaluate. I have NOT found people claiming the Diamond Pistons are shattering. Maybe I didn't look in the right places but it seems to carry high regard. I checked on the Ross pistons but they were well over $700 and I don't think that was with wrist pins. I settled on the 5.7" -31 Diamonds with Total Seal AP series rings. This, after conferring with Eric at Victory. They were $770.99 for Pistons/rings and shipping/handling. Thanks for the input everyone!
I had the 224/236 Extreme w/1.6 roller rockers
(224/236 .537/.556 112 Xtreme) using the Crane 10308-1 spring kit in my prior 355. On pure motor, driving off the highway, switching to ET streets in a full 3,650lb TH350 2800 vigilante equipped street car, I went 12.0 at 116 mph. Added a 100 shot from an NX kit for the next pass, 11.1 @ 121. Add to that, the cam sounds wicked at idle....
http://www.taekwondoplus.org/z28/224Idle.mpg
Hmmmm.... I may go back to that cam. Did you have to special order that LSA? I bought my 224/236 3rd hand (Denny McClain, Mike Graham used it before I bought it from Mike) and it may be special ordered with the 112 LSA for all I know.
I would. Consider a 1.7 intake rocker, though, to get some lift out of it. I'm using high lift lobes for .605 intake with a 1.6.
Yea, it was a custom grind from Comp.
Mike
Mike
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
