m6 vs auto w boost
Old Oct 30, 2007 | 09:46 AM
toryblownss's Avatar
m6 vs auto w boost
my m6 hates my @600rw supercherged 383!! only 33K miles on car and neeeds 2nd rebuild.The gears wine it doesn't shift good(barely takes 2nd at all) its a 97 ss car and I hate to take it out but really thinking an auto w/ a trans brake may be the way to go!! What do you guys run??? I know you can build the m6 to hold alot but its not cheap!!How big of a job is it to swap to an auto??? Curious what you guy's run and how they have held up on the street along with some hard launches!! BTW motor has 4K on it and tranny was fine till then!! any type of input is appreciated
Old Oct 30, 2007 | 09:54 AM
Sparkz28ss's Avatar
I bet the **** out of my M6...one of them is stock (edit: w/ spec 3i)and the other is a little built up with hardend shafts and good syncros.What keeps breaking in yours?
Old Oct 30, 2007 | 10:20 AM
CALL911's Avatar
I have beat the living snot out of my 95 M6, and other than replacing the clutch to a SPEC stage 3, it is all stock (including a stock flywheel). My RWHP numbers are in my sig, and I have ran slicks on it often, and it has never given me any problems.
The stock LT1 M6 will hold a lot of HP, however regular maintenance is expected. An LT1 Auto won't take nearly the abuse. You could always upgrade either to an aftermarket auto, or aftermarket M6.
Old Oct 30, 2007 | 11:11 AM
jammer94's Avatar
me too i also beat the snot out of my m6 and its on a 4200lb car they hold good HP but its the torque side where they are there weakest, i guess its all in how you laucnch to, how do you launch your car with those 600HP
Old Oct 30, 2007 | 12:38 PM
tranny guy say's its the blocking ring this time,first time was shift fork. I'd like to just build it stronger but want to know if its worth it??? I'd like to get it to run in the nines soon and don't know how hard it will be with m6??? I leave @5K and get 1.60 60 ft. times w/ full weight car which is why gears wine?? Any of you runnin a m6 in the 9's consistently or even deep 10's??
Old Oct 30, 2007 | 07:48 PM
97s10ondubs's Avatar
Mid 10's, launching mine off the limiter on a 200 shot, my t/o bearing is bent and that's it . I did put in a steel 3-4 fork, new blockers, and bronze shift pads.
Old Oct 31, 2007 | 12:21 AM
I haven't been brave enough to leave on the limiter but i may try it tomorrow night in Darlington, I bet your 60ft times on a 200shot are darn good. Your car looks identical to my 97 when I first bought it other than year changes.
call911 if you don't mind what kind of times do you run1/8 n 1/4
97s10 what your 60ft n 1/8 times
Old Oct 31, 2007 | 06:17 AM
Still not amazing, the car bogs until the spray hits, which is like 5-10 feet out. 1.62 is my best, 6.90 in the 1/8 at 104.
Old Oct 31, 2007 | 09:47 AM
CALL911's Avatar
Actually, my 614 RWHP Z hooks up in 1st gear with cold Nitto DR's, so its very easy to launch. Here's a video of me running against my buddies C5 Twin Turbo.
Click here to see Video
Old Oct 31, 2007 | 12:07 PM
LittleRedZ's Avatar
if you drive the car daily i would recomend 4l80e, its got an overdrive you can cruise all day and with a good converter will pull low 1.4 high 1.3 numbers with right suspension all day long.
Old Oct 31, 2007 | 08:19 PM
OBE1 95Z28's Avatar
Your problem could also be with your shifting technique, power shifting will cause the tranny to fail early. I've got 156K miles on my stock T56 with 593 rwhp. Most of the driving is on the street but it's seen 50 passes at the drag strip and is currently used to road race at Willow Springs.
Old Oct 31, 2007 | 10:53 PM
jammer94's Avatar
cool vid.
Old Nov 2, 2007 | 07:20 AM
sandman2100's Avatar
NIIIIIIIIIICE!
By the way, someone needs brakes in that vid. ouch.
Old Nov 2, 2007 | 03:47 PM
CALL911's Avatar
Originally Posted by sandman2100
NIIIIIIIIIICE!
Thanks for the compliments. Its my brakes that are chirping, and unfortunatly, its not because they need changed. I wanted to go all out with my brake pads for my Baer Track Pro system so I ended up going with Hawk HP Plus pads. They stop hard enough to make you feel like you are going to go through the windshield at high speed braking, but they chirp everywhere, and it is really annoying. I think the annoying factor is greater than the stopping factor though, in the sense that when they wear down, I might go for the Hawk HP pads that are a level below my HP Plus pads next time.
Old Nov 2, 2007 | 09:11 PM
DirtyDaveW's Avatar
Love the video. Pretty amazing take off on the street. I expected there to be more skating around, searching for traction. Great show there!
