Track results...stock heads/cam T76
Old Nov 4, 2007 | 06:23 PM
1982z28with18s's Avatar
Finally got to hit the track yesterday for the first time with this setup, the tune is still VERY conservative with only 15 degrees of timing and a 11.2 afr(11.8 in top of 3rd when the maf maxes out). I was pulling 6lbs in 1st and 2nd, and peaking 8lbs toward the top of 3rd gear.
Quick rundown on my setup...
9.5:1 355
stock crank
eagle rods
wiseco pistons
STOCK heads
STOCK cam
STOCK intake
STOCK throttle body
1.6rr's
stock th400 with a 4000 nitrous converter(not a good setup for the turbo)
3.42's
stock chrome wheels with 28x11.50x16 et streets
qa1's, bmr lca's, and bmr tq arm
Realquick's hot parts
Turbonetics T76 q trim ball bearing .81 ar
44mm wastegate
Joe P MBC
RFL bov
FMIC
All coldside piping custom done by me
42lb injectors(maxed out)
stock maf(maxed out)
Tuned by myself
I drove to the track, on 91 pump gas, didn't adjust my air pressure or any of my supsension either, just ran these times.
First pass I left off idle, just barely preloading the suspension.
1.76 60ft
7.42 1/8
95.4 1/8
11.49 1/4
120.93 1/4
Second pass I foot braked to about 2800(nitrous converter is tight), and launch with about 4" of vacuum since I couldn't build any boost.
1.63
7.26
95.69
11.32
121.39
Third pass, I pulled the ebrake and built right at 1lb of boost
1.56
7.15
95.77
11.21
121.24
Fourth pass, pulled the ebrake again, built right at 1/2 lb of boost
1.58
7.15
95.89
11.21
121.67
Final pass, pulled the ebrake again, got 1 lb of boost, but the track had gone away so I spun
1.63
7.27
96.05
11.33
121.39
Here's a video of my first pass and my 3rd pass, sorry I didn't edit them at all, just uploaded real quick since my laptop is having problems.
http://media.putfile.com/turbo-formula-track1
http://media.putfile.com/turbo-formula-track2
Megasquirt and bigger injectors will go on soon, 10's on stock heads/cam and on pump gas won't be a problem at all.
Old Nov 4, 2007 | 07:28 PM
RealQuick's Avatar
Awesome! Car sounds sick during the burnout!!!
Old Nov 4, 2007 | 07:36 PM
RedRyder518's Avatar
NO KIDDING! Your car launches so smoothly, it almost doesn't look like a 1.5x 60'.
Old Nov 4, 2007 | 07:46 PM
toryblownss's Avatar
get a trans brake and leave under boost
Old Nov 4, 2007 | 07:49 PM
RealQuick's Avatar
I am still waiting on some street racing vids...
Old Nov 4, 2007 | 09:36 PM
RealQuick's Avatar
Easy 10's for Justin if he ups the timing at the current boost level.
Old Nov 4, 2007 | 11:09 PM
I know, I need to get it up'd!
I blew up my th400 that had the transbrake in it.
Hopefully my laptop gets fixed soon, I have so much video that I need to get uploaded.
Thanks, it honestly reminds me of a grand national. One guy took a pic and on the launch I actually wrinkled the sidewall on the 16's.
Old Nov 5, 2007 | 07:22 AM
97WS6Pilot's Avatar
Nice 60's.
Old Nov 5, 2007 | 07:30 AM
Originally Posted by 97WS6Pilot
Nice 60's.
Thanks, I was pretty happy with them considering it was on the 16's and this 11.50 is NARROW. I think with a few more passes and adjusting the suspension, along with a 2 step and it will go 1.4x 60fts on the 16's.
Old Nov 6, 2007 | 10:40 AM
JohnnyPappis's Avatar
Very nice! It makes me really really look forward to what ive got in store for my own setup! can wait to see what shell do with all of the minor things worked out congrats man!
Old Nov 6, 2007 | 10:41 AM
Nice times! cant wait to see what it does with all the minor little things worked out
Old Nov 6, 2007 | 10:44 AM
RealQuick's Avatar
A certain mustang better go run and hide...
Old Nov 6, 2007 | 11:08 AM
Sparkz28ss's Avatar
nice times..
sounds nice too
Old Nov 6, 2007 | 04:44 PM
Tricked-Out-Toy's Avatar
you have exactly what im building, with the exception of the heads and cam. Im going with a custom cam and I have LE3 heads. do you have any pics detailing the hot side piping and are you running a intercooler?
Old Nov 6, 2007 | 08:03 PM
Do a search on my old posts, I've talked a lot about my exact setup, realquick built the hot parts, and I build the cold side with a fmic.
With heads/cam, and timing up, I could see 130mph on 8lbs without any issue.
